tranny swap
Old Mar 18, 2011 | 11:45 AM
beaudonahue's Avatar
tranny swap
ok i have a 84 camaro automatic with a 350 motor the tranny slips so i am going to change it to a stick i have a 82 parts car that is a stick already my question is what all do i need i have looked alittle and i havent found just a list of ever thing i need and another question is did 82s come with a t10 four speed?
Old Mar 18, 2011 | 02:17 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: tranny swap
Is the parts car a v6 or v8 as that will make a huge differance with the transmission. I take it in the 82 is a T5 transmission for the swap. T5's where not ment to be behind a 350 but I know a few guys that do it but only use their cars for drivers and dont beat on them. We had a T5 behind a 383 once to see if it would last till the end of the season and it laster 3 days at best but thats another story. The list of stuff you need for the swap is
--- Trans
--- Trans bolts that where used to mount to the block on the bellhousing
--- Slave and resivoir under the hood and allthe hardware for it
--- clutch pedal assembly
--- torque arm mount and hardware
--- all the wiring that goes to the tranny as you will have to wire them up for the reverse lights to work and will need to bypass the neutral safety switch
In the interior
--- Center console piece with boot
--- floor rubber boot and harware
This is I think everything you need for the swap. If you have access to a welder you can cut the ring out of the 82 for the floor boot and weld it to your 84. If not metal screws work fine
Hope this helps
Old Mar 18, 2011 | 08:58 PM
Re: tranny swap
its a v8
Thank you very much
Old Mar 19, 2011 | 04:37 AM
6SIX6's Avatar
Car: 89 IROC
Re: tranny swap
If i think of anything I missed ill let you know as Ive done the swap 4 times this year for friends and my car
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
