700r4 to turbo 350
Old Mar 20, 2011 | 09:13 PM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
700r4 to turbo 350
may convert to a turbo 350. a few questions. can i use the same crossmember? will the stock shifter stiil work? if i use a 9" tailshaft, will the 700r4 driveshaft work? how do i get the torque arm connected to the 350 trans? not looking to buy the spohn arm
Old Mar 20, 2011 | 09:51 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: 700r4 to turbo 350
Your cross member will work but you need to buy a kit like this http://www.summitracing.com/search/b.../?autoview=SKU It includes the torque arm mount and cross member mount, your driveshaft will work if you have a 9in tail shaft or you can use a 6in housing and look for a 82 F-body auto driveshaft. The shifter will work. Good luck.
Mark.
Old Mar 21, 2011 | 01:18 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
For the torque arm mount look for a Monza (H-body) TH350 tail stock it has the torque arm mount but it is a 6" so you will need the 82 drive-shaft.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
camaro11j
Sep 19, 2018 08:49 AM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
