Weird 700R4 slipping issues
Old Apr 1, 2011 | 08:10 AM
jt1562000's Avatar
Car: '88 IROC-Z
Engine: 383 Stroker
I searched through a ton of posts here and couldn't find anyone with the same problems I am having. i have rebuilt a few 700's but never seen one with this problem. I would appreciate a little help, thanks!
Spec's: Carbed 383 putting out about 420 hp 440 tq
2400 stall converter
T.V. cable is correctly adjusted
I have been babying this transmission while saving for an upgrade, so it has little to no abuse since I bought it.
I drove home from work at about 8 pm and had no issues. The next morning when I left for work I had bad slipping in 1st and 2nd, but 3-4 have no ill effects that I felt.
I checked the fluid and it is sitting a hair under the top of the checkers when hot, but is full of bubbles. Fluid is a decent red, has no noticeable particles in it, and doesn't smell burnt. It has been about 10,000 since my last filter/fluid change.
What would cause slipping and bubbles besides being over/under filled? My only thought was if my filter neck cracked and was sucking air instead of fluid, resulting in a loss of pressure. (or my 1-2 clutch pack is flopping around in the pan causing agitation )
Any Ideas? Thanks!
Old Apr 1, 2011 | 07:01 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: Weird 700R4 slipping issues
The forward apply piston may have cracked. Just had one here do the same thing, and that is what it was.
Old Apr 3, 2011 | 08:27 PM
jt1562000's Avatar
Car: '88 IROC-Z
Engine: 383 Stroker
Thanks for the tip. Im going to tear it apart this week and see. Ill let you know what I find.
Street Lethal
Apr 30, 2019 12:14 PM
Cleotiz
Jan 6, 2018 08:56 PM
maroe624
Apr 16, 2017 08:29 AM
someone972
Aug 30, 2015 12:52 AM
CORV3TT3
Aug 23, 2015 11:26 AM
