700r4 leakin fluid out dipstick tube hole dont know why
Old Apr 3, 2011 | 05:15 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
Transmission: 700r4 w/huges 3000 stall
Axle/Gears: 3.73 posi
i just got a new 700r4 in the car over the weekend, i have a huges 3000 stall that was in the old trans that lost 3rd gear. shifts and works fine but it leaks trans fluid out of where the dipstick tube goes into the trans. i have pulled the tube out and cleaned it and made sure the gromet was correct. what else could be the cause of the fluid running out or has anyone had this similar problem. would like to get it fixxed before i have to get another trans. thanks.
Old Apr 3, 2011 | 07:39 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: 700r4 leakin fluid out dipstick tube hole dont know why
is it seated in all the way? Is there a tube itself leaking? Ive seen sometimes there is a pinhole from rust. Also check the cooler lines, make sure they arent leaking and running down the trans to make it look like the tube seal is leaking.
Old Apr 3, 2011 | 08:46 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
If it is the rubber grommet, try some silicone seal on the grommet and reseat it.
Old Apr 3, 2011 | 09:59 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
no its not the lines you can clearly see it leakin while its running, will probably have to silicone it but would really rather not
Vojtush31
Oct 11, 2015 01:07 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
