questions on shifter wires
Old Apr 10, 2011 | 09:17 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
i bought a b@m megashifter. I dont remember what plugs i took off the stock shifter. Question is the long plug that the neutral safety switch harness is on, besides the purple and yellow wire (witch is nuetral safety) What are all the other wires for in the plug? All i need to hook up is the reverse lights, and nuetral safety. Can i cut the other wires?
Next question. In the harness for the trans i have a 4 prong plug, and a 2 prong plug. The 4 prong is hooked up but where does the 2 prong go too? i dont see any places for it too plug into.
Thx for the help
Old Apr 10, 2011 | 09:31 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: questions on shifter wires
the 2 prong by the trans is the speed sensor, its on the tail shaft, driverside i think?
the 4 prong is the converter control wiring for hte lockup.
the other wires on the shifter are the reverse lights, and a lock out for the rear hatch opener, so you can t open the hatch when the car is in gear.
camaro11j
Sep 19, 2018 08:49 AM
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
