94 caprice trans problem/questions (trans rebuild)
Old Apr 12, 2011 | 11:24 PM
dustin3207's Avatar
I new something was wrong. because a couple times it took to long to find a gear and 2 times it didn't find anything till i let off. so this morning i brought my car in to have the trans-go shift kit put in it and a trans flush.
when the tech/owner took off the trans pan he found a 1/4 inch of fine gooey clutch stuff in the bottom of the pan. should also mention that the 2 little screens on the valve body plate were plugged up so bad that they collapsed a bit. He recommended i rebuild it.
i want to know what stall i should go with being i have to replace the converter (1600 or 2000 stall)? he said to go with the 1600 stall because its a daily driver.
56,000 original grandma miles on car
__________________
Old Apr 13, 2011 | 05:31 PM
Badasscamaro346's Avatar
Car: 87 camaro
Engine: v8 carb'ed
Transmission: 5 speed
Re: 94 caprice trans problem/questions (trans rebuild)
sounds like a heavy footed grandma. LOL. What do you plan on doing with the car? weekend track toy? daily driver only?
Old Apr 13, 2011 | 07:12 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Gotta lock this for not being thridgen Camaro/Firebird related.
Infested
May 22, 2018 11:56 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
fbirdroller
Sep 2, 2015 10:27 PM
camaro71633
Sep 1, 2015 10:24 AM
hokis
Aug 9, 2015 03:57 PM
