700R4 Issue
Old Apr 15, 2011 | 11:01 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
700R4 Issue
First start up let it idle for a minute, rpms at 1500, shift from P to R or P to D, get a hard pound from the car. Honestly it shook the whole car thats how hard it was. It happens alot, sometimes its smoother, sometimes its non-existent but mainly it'll happen alot and i'll feel the hard knock, its not smooth like most people say the 700r4 should shift.
Wanting to know if anyone else has had the same problem and how you fixed it.
I bought a new tranny mount, hoping to install it soon and see how far that gets me, but I just don't know what it is.
Old Apr 15, 2011 | 11:10 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: 700R4 Issue
1500 park idle is kinda high to me
My drive idle is 650 carbed and park is about 800
Your high idle is slamming the drivetrain
Could be worn u-joints or the trans internals are wearing but don't fear, there is always some trans slop
Try bringing your idle down and have your u-joints checked
Old Apr 15, 2011 | 11:27 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 700R4 Issue
sorry i should re-phrase that, my idle is normally 650-750 but morning starts thats where i let it sit and drive to work and let it idle drive me. but mainly even at 650-750 it'll still give a kick. I'll check the u-joints
Old Apr 21, 2011 | 11:40 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: 700R4 Issue
i had the same issues before. damn thing would idle high for too long then it would come down to 650ish. sometimes just didnt have the time to wait and had to let it hit. never figured it out tho. trans was a rebuilt unit before i got it. i ended up changing the driveshaft anyway and the hit wasnt so hard afterward. hope yah find it.
Old Apr 23, 2011 | 08:45 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 700R4 Issue
replaced the tranny mount. while unbolting the tranny mount it fell off, looked at it, the rubber was split in half. that solves i think half the problem, the banging doesnt happen now when i give it gas like it did before. but i still get a kick from shifting gears. i noticed the torque arm mount is cracked to hell so thats next and hoping for the best. is the dealership the only option or can i get it online?
Old May 1, 2011 | 02:55 PM
86Zguy's Avatar
Car: 1986 IROC-Z, 1984 C10
Engine: 5.0 305 V8
Transmission: 700R4 Auto
Re: 700R4 Issue
mine did the same thing but my problem was a broken shift kit
Old May 2, 2011 | 05:03 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 700R4 Issue
broken shift kit?
Old May 4, 2011 | 10:20 PM
86Zguy's Avatar
Engine: 5.0 305 V8
Re: 700R4 Issue
Yea the guy before me had a shift kit on it so it would shift at a higher rpm at WOT but it jacked up the trans so I had to get it rebuilt
Old May 5, 2011 | 05:33 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: 700R4 Issue
Are you having trouble with a high idle when it should be at about 700 ish? It sounds like a tranny mount to me. Easy fix. If you are having trouble with the idle, you might have an IAC issue.
Old May 5, 2011 | 07:20 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: 700R4 Issue
i dont think i have a shift kit.
i replaced motor mount, it helped alot, but now i still get the thump here and there, i noticed the torque arm bushing is shot so now i have a found a new one.
any ideas where online i can?
Old May 6, 2011 | 02:34 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Re: 700R4 Issue
This?http://www.jegs.com/i/Energy-Suspens...oductId=743946
jklein337
Sep 19, 2018 06:23 PM
TheTraut88
Sep 7, 2015 05:22 PM
Americanmouse
Sep 7, 2015 12:10 PM
greenyone
Sep 2, 2015 03:39 PM
someone972
Aug 30, 2015 12:52 AM
