wheel seal on a 3.27 posi
Old Apr 21, 2011 | 10:57 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
wheel seal is leaking on my right side. i'd like to repair it before things get worse. i know you may need special tools to dig into a posi rear end. what all would i need to do? how difficult is it?
Old Apr 22, 2011 | 07:16 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: wheel seal on a 3.27 posi
Summit has the wheel seals for the 9-bolt rear (right & left). You may as well relace the bearing because you will in most cases damage them to replace the seal. With the 9-bolt you do not need to open up the internals, NO "C" clips on the axle shafts.
Old Apr 22, 2011 | 07:45 PM
Engine: 350 L98/LS2
ok cool. so that sticky up top will pretty much explain it then? i was reading through it and it seems like it may be pretty difficult.
1992 Trans Am
May 10, 2023 07:19 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IroczFan
Oct 6, 2015 10:13 AM
Dialed_In
Aug 20, 2015 01:45 PM
