Hydrulic Clutch leaking, HELP!!!
Car: 1989 Iroc-z camaro
Engine: 305ci HO
Transmission: manual 5speed
Axle/Gears: Borg Warner w/ 3.08 gears
I have a stock clutch in my 89 but it refuses to function bucause it is leaking most of its fluid out. Not sure if it's just a line leaking or the clutch master cylinder. Any other possilbe explanations? I heard that if i have to replace a line i'm better off replacing the entire master cylinder to prevent futher problems. I was also thinking the throwout bearing could be worn preventing the clutch to engage. Thoughts appreciated.
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
Re: Hydrulic Clutch leaking, HELP!!!
from what i have heard from a bunch of people is the line on there is prone to crack and leak. The bad thing about it is that you cant get the part from the parts store unless i am wrong.(thats what someone told me) will have to have one made. I had to have one made for my car
Engine: 305ci HO
i found a clutch master cylinder on classic industries website but it didn't have any additional line. it was just the master cylinder. Thanks for the info.
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Try NAPA. I think you can get a clutch master with a pressure line already connected.
Engine: SBC 350
My clutch master is leaking also, only mine is leaking from inside the car, where the rod goes in. I'm doing a T-56 swap and I think my master cylinder geometry is off. I must have busted the seal in the cylinder. I'm trying figure out how i could have mounted it wrong because I used the mounting bracket as a template to drill the holes. My clutch won't disengage completely, and i can't get the trans into gear with the car running. Which leads me to believe that my bogus geometry is not giving me the proper amount of throw.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Engine: SBC 350
No. I have not driven it since I swapped the trans. Well, I tried to drive it around the block once, but it was not good. I really have to yank on it to get it out of first.
Car: 1984 Trans am
Engine: 305 H.O.
I'm having the exact same problem. Have had the trans out a few times now, and now all it comes down to is the hydraulic system.
Drone358
Dec 10, 2015 08:16 PM
Night rider327
Sep 2, 2015 04:17 AM
