T5 swap question
Old May 4, 2011 | 11:23 AM
Ivos's Avatar
Car: 1991 Camaro RS
T5 swap question
Ok so I did the T5 swap in my car, finished up everything, drives nice big improvement over the auto, actually makes this car fun to drive.
Here's my question(I did a search and couldn't find what I was looking for) The cars a 91 RS, came from the factory with the 305 TBI and automatic, I put in a T5 from a 90 camaro. Cars stock other than an exhaust. Do I have to do anything to the computer? should I put in a computer from a manual? I mean it drives fine the only thing I noticed is it idles really high when its first started, but then goes back to normal after about 5 minutes
P.S. I dont care about check lights coming on or anything, the car only gets a safety inspection where I live.
Thanks again
Old May 4, 2011 | 12:26 PM
Re: T5 swap question
If I may paraphrase Duke Ellington:
"If it RUNS good, it IS good".
I'd suggest leaving it alone. At most, locate the PROM out of a T-5 car.
Old May 4, 2011 | 09:38 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yes. And the park neutral switch is functionally stuck in "Drive" in stick cars.
Subtle, but should be done.
Old May 5, 2011 | 10:46 AM
Ivos's Avatar
Car: 1991 Camaro RS
Yeah I have that stuck in drive taped it up and stuck it under the center console, So if i get a Computer off a manual I can eliminate the shifter when it was an auto?
Old May 5, 2011 | 12:16 PM
The P-N safety sw is the same, electrically, as the clutch safety sw.
Auto = won't start unless in P or N
Manual = won't start unless clutch is to the floor
Just plug that plug into that other switch. I would have expected that to have been done as part of the conversion.
Old May 5, 2011 | 03:09 PM
jmd's Avatar
jmd
There's a park/neutral switch which signals the ECM in an automatic car when in "Drive" for different idle at roadspeeds and other functions. (An auto car with original PROM, park-neutral switch in Park and a stick trans. swapped in will tend to stall while you're driving at speed.)
There's also a clutch safety switch; usually on the left side of the pedals on later third gens, with purple and (?yellow?) wires. That's a separately functioning and wired item.
Old May 5, 2011 | 06:48 PM
Ivos's Avatar
Car: 1991 Camaro RS
[quote=jmd;4912620]There's a park/neutral switch which signals the ECM in an automatic car when in "Drive" for different idle at roadspeeds and other functions. (An auto car with original PROM, park-neutral switch in Park and a stick trans. swapped in will tend to stall while you're driving at speed.)
Luckily I haven't had any of these problems, What exactly is the PROM? its a different part than the computer correct? Can I get one at like Advanced Auto?
Pardon my ignorance this is my first experience doing stuff like this and so far Ive been able to do it all on my own, The write i got off this website didn't really mention any of this stuff
Old May 7, 2011 | 01:09 PM
jmd's Avatar
jmd
Programmable Read Only Memory (PROM) is the chip assembly inside the ECM (computer.) A manual computer is the same as the automatic; only the PROM is different. Easy to change out; your ECM should have a cover retained by a couple screws.
You'd be fine with a TBI / 5spd PROM from a 90-92 F-body. Try the classifieds.
Old May 7, 2011 | 05:57 PM
Ivos's Avatar
Car: 1991 Camaro RS
Oh ok its just the chip, Thanks for all info man!
Old Jul 14, 2011 | 01:26 PM
Ivos's Avatar
Car: 1991 Camaro RS
bumping this back up, I'm having issues with the reverse lights. I cant get them to work. If someone that's done this swap could enlighten me it would be much appreciated.
Old Jul 14, 2011 | 02:37 PM
jmd's Avatar
jmd
Find the plug for them that used to hook up to your auto shifter.
If you apply 12v to that and it lights up the reverse lights, you need to extend the wires & add a connect to connect that to the 2-pin switch threaded into the side of the trans.
Pretty straight forward.
Old Jul 15, 2011 | 07:02 PM
Ivos's Avatar
Car: 1991 Camaro RS
I tried every wire coming off the auto shifter, and i put a new two wire connector coming off the tranny. I thought i read that its the blue and green wires, but those arent working.
My tranny does grind a bit going into reverse, could this cause them no to work?
Old Jul 15, 2011 | 10:52 PM
jmd's Avatar
jmd
R is not synchronized in the T5.
Put it in 4th before going into R.
The switch is activated off the linkage and shouldn't be the cause of a grind.
Old Jul 20, 2011 | 04:49 PM
Ivos's Avatar
Car: 1991 Camaro RS
I know my question was if the grinding would cause the switch to not work, but i got the reverse lights working, turns out both the light bulbs were burnt out. Should have started simple
Old Jul 5, 2014 | 03:06 PM
rocn7roc's Avatar
Hi I am doing this conversion also,what wiring changes do i need to make ,neutral switch ,clutch pedal switch, steering column lock cable fro auto shifter Thanks Mike
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
