clutch pedal question
Old May 5, 2011 | 10:28 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
On my old auto brake pedal there were two sensors or switches. Which one is for the brake lights? I'm doing a manual swap and I want to just hook up the clutch depress switch and the brake lights will that work?
Old May 5, 2011 | 10:35 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: clutch pedal question
The long, skinny, cylindrical one is for the brake lights. The other one is for the cruise control if I had to guess.
If you want the clutch switch to work you have to wire it into the automatics neutral safety switch located in the shifter area of the center console.
Old May 10, 2011 | 11:59 AM
Both switches were squareish so I'll just put the old switches on the new brake pedal and then I'm just going to wire the safety switch wires together
1992 Trans Am
May 10, 2023 07:19 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
