T5 output shaft play
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I have the tailshaft off my 89 WC T5 to change the speedo gears. If I grab the shaft and move it side to side there is quite a bit of play. Is this normal? Id have to guess its about 1/8" all the way around (moving it side to side, up and down)
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: T5 output shaft play
There's a bushing in the tailshaft housing that's pretty easy to change out since you have it apart anyway. I "think" it's called a yoke suport bushing... I think what really matters is what kind of play do you have with the front driveshaft yoke installed on the splines?
Received 1,676 Likes
It is normal.
There's really nothing keeping that from happening, except the extension housing bushing which supports the drive shaft yoke, which in turn supports the mainshaft. Take away those 2 supports, and there's nothing there to keep it from wobbling any more.
Car: 1988 Iroc
Engine: 5.7L
Thats exactly what I thought, just double checking.
TMZIrocZ350
10-07-2015 12:09 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
