Zoom clutch install
Old May 29, 2011 | 01:34 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Zoom clutch install
I am installing a zoom clutch kit. The clutch has two surfaces one looks solid without any breaks in the material, it is light brown color.
The other side of the clutch has a more traditional looking gray/black material, looks like the old clutch.
question is which side faces the flywheel and which side faces the pressure plate?
Old May 29, 2011 | 02:08 AM
palric's Avatar
Re: Zoom clutch install
was able to answer my own question at zoomclutch.com
the light brown side is kevlar and faces the flywheel
the other side is normal clutch material, faces the pressure plate
Old May 29, 2011 | 08:51 PM
palric's Avatar
update - their web page lies
the only way this setup will work is with kevlar facing the pressure plate which is opposite of what the document says. so i installed it the only way it will fit.
will follow up when i road test this setup
Vintageracer
Jan 10, 2020 05:33 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
86IROC112
Aug 17, 2015 07:57 PM
Street Lethal
Aug 12, 2015 11:33 AM
rsrmoore
Aug 7, 2015 08:44 PM
