bad tv cable?
Old May 30, 2011 | 11:21 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
bad tv cable?
just put my old trans back in the car as the "newused" one was always at 2000 rpm at any speed and had no *****, my old trans shifted perfect and had lock up working. now i put it back in and adjusted the cable and it shifts like crap. trans was a 12,000 mile rebuilt. i drove it the 12,000 miles. it was a tbi car. now it is tpi and i did use a tpi cable. it came with this drivetrain i bought to convert. that trans shifted excessively hard but had no lock up and like said above was always at 2000 rpm regardless of speed. can the cable be shot out of the blue? i can barely feel the difference in gear shifts till lock up occurs. wtf? or are their differences in the tbi/ tpi transmissions? hope someone has an idea cause i have to go to work tomorrow and i really don't wanna roast another transmission. the wife will kill me!
Old May 30, 2011 | 11:40 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: bad tv cable?
Adjusted?
Or adjusted, drove it to test, and adjusted it until it was right?
You could pull the pan to adjust it too.
Old May 30, 2011 | 11:54 PM
Car: 91 formula ws6
Transmission: 4l60E
Re: bad tv cable?
adjusted as soon as done with swap, then drove up and down the block, re adjusted, then drove home 2 miles. it was ehhhh not the best. just didn't feel like it did b4. really kinda bummed. was going 40 mph at 1100 rpm. shifted into 4th at 35mph at part throttle. it always shifted alittle early even with tbi on top but it always hit the gears correctly. ehh. ill check again tomoro morning.
Old May 31, 2011 | 12:44 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: bad tv cable?
sounds like you need to adjust it again. I had to fine tune mine for days to get it where I wanted it! haha.
Old May 31, 2011 | 10:07 AM
Car: 91 formula ws6
Transmission: 4l60E
Re: bad tv cable?
wondering if it may have stretched? i dont mind tweaking it. not like i haven't had to in the past.
Old May 31, 2011 | 10:42 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: bad tv cable?
This link has a lot of good info; http://www.tvmadeez.com/index.php
MM2Robinson
Oct 1, 2017 09:16 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
