How do you disconnect the shift cable from the shifter?
Old Jun 2, 2011 | 01:27 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
On a 700r4 how the hell do you disconnect the shift cable from the shifter? My oh so awesome haynes has no info on it, and its hard to see how the cable is actually attached because theres stuff in the way.
Old Jun 2, 2011 | 10:23 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: How do you disconnect the shift cable from the shifter?
Disconnect the cable from teh shifter inside the car? Are you trying to change the cable? to remove it? The end of the cable connects to a pin sticking out on the shifter assembly. thier is a clip that pushes thru and holds it from coming off. now the shifter also clips into the shifter bracket. To get that out you squeeze the sides (they are plastic) and it will pull out.
Old Jun 3, 2011 | 11:49 AM
Engine: 3.8, 3.4
I got it off that day actually, bit the bullet and pried it off the pin with a screw driver after looking at it a while and deciding that it just clipped onto the pin, now I just have to get ahold of a new rotary tool to cut a plate to mount the shifter to...though I wonder if there is an easier way..
wigmobile
Feb 26, 2025 02:56 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
tonys91rs
Sep 2, 2015 07:07 PM
