what t56 should I buy?
Old Jun 3, 2011 | 06:50 PM
Lippard9202's Avatar
Car: 1986 Iroc
Transmission: 7004r :(
hey guys, I currently have a 1986 iroc, with a 305 and a 700r4... Im wanting to swap both eventualy, but for now im just going to do the trans. I would really like a 6 speed, but one that will be able to be used with my 305, and also later with an Lsx... I know the 305 doesnt have enough power to be in 6th gear all day, if at all, but what should i do to my 305 in the meantime? it does need a tune up, but anything else i should do while i have that done? but back to the trans; what donor car should i look for? and can i use a console from a 3rd or 4th gen? or will i have to cut and fab it myself? and what ALL parts should i get from the donor? all answeres are very much apreciated, thanks!
Old Jun 3, 2011 | 07:56 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Re: what t56 should I buy?
"my t-56 swap thread" At the top. Read it.
Old Jun 3, 2011 | 08:05 PM
Car: 1986 Iroc
what exactly are you wanting me to read? Im new to forums like this so im not sure what to look for.
ok, i thought you were saying read it at the top, not the THREAD at the top, my bad. Im working on it
Old Jun 9, 2011 | 09:14 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
stay away from the 1993 six speed.the later ones have a higher overdrive.....50.
Old Jun 9, 2011 | 09:51 PM
Car: 1986 Iroc
thats what ive read, they are also weaker, but i was wanting a tranny compatable with the engine i have now, and later for when I get an Lsx.
Old Jun 9, 2011 | 10:07 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the key here is "later used for LSx swap" basically you need the t-56 that came stock behind the LT motors to use with your 305. however you cant run that trans behind the LSx motor without modification. The LS t-56 uses a longer input shaft and has 1 less bolt on the bellhousing.
Old Jun 9, 2011 | 10:10 PM
Car: 1986 Iroc
I see... so should I use an ls t-56 now and just mod it to fit my engine?
or buy a t-5... haha
Old Jun 9, 2011 | 10:13 PM
travis401's Avatar
Car: 91 Camaro RS
you can make a LSx t-56 work behind a 305, Ive done it. However its going to cost more in the long run because youll have to buy swap parts now and different swap parts when you go LSx. You just wont have to buy another trans.
Old Jun 9, 2011 | 10:34 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Also, check out this thread I created:
https://www.thirdgen.org/forums/tran...-overview.html
Old Jun 9, 2011 | 10:36 PM
travis401's Avatar
Car: 91 Camaro RS
Thats great info for the LT t-56 swap, which wont work with a LSx motor.
Old Jun 9, 2011 | 10:41 PM
Car: '91 LS6/T56/9"
Engine: LS6
Yep, but a lot is still relevant. Only difference would be the bellhousing/clutch considerations if using an LS T56 with a SBC/BBC. Mounting, electrical, shifter, crossmember, ect all the same for both.
Old Jun 9, 2011 | 10:49 PM
travis401's Avatar
Car: 91 Camaro RS
Actually to use a LS t56 on a gen 1 SBC, you have to use an adapter plate or a conversion bellhousing. either way, it pushes the trans further back (to accommodate the longer input shaft) so the xmember has to be set further back, the drive shaft has to be shorter. so the LT t56 swap parts dont work on an LS t56 behind a gen 1 SBC
Old Jun 9, 2011 | 10:51 PM
travis401's Avatar
Car: 91 Camaro RS
And not to mention the LS t56 uses a hydraulic TO bearing, so the hydraulics arent the same.
Car: '91 LS6/T56/9"
Engine: LS6
Good call with the crossmember and driveshaft. Just forgot.
Old Jun 9, 2011 | 10:53 PM
Car: '91 LS6/T56/9"
Engine: LS6
I was thinking more about mounting to the firewall which is the same, but yes completely different hydraulics.
Old Jun 9, 2011 | 11:03 PM
travis401's Avatar
Car: 91 Camaro RS
I personally use the t-5 bell, clutch and hydrualics (just because my car came stock with the t-5). I just run the adapter plate to bolt the LS t-56 to it. But for the OP, hes switching from an auto, so that option doesnt make much sense.
The OP has a few options.
#1 buy everything to swap in the LT t-56 now and buy everything for the LS t56 when swapping to the LS motor.
#2 buy everything to swap the LT t-56 now and swap to a gen1 SBC later instead of LSx (no need to replace any part of the trans swap).
#3 buy everything to swap to a t-5 now and buy everything for the LS t56 when swapping in the LS motor
#4 leave the auto in and swap to an LSx motor and LS t56 later.
Old Jun 10, 2011 | 11:18 AM
Car: 1986 Iroc
so what would you suggest?
Old Jun 10, 2011 | 11:36 AM
travis401's Avatar
Car: 91 Camaro RS
If youre dead set on the LSx motor, id suggest wait and swap the motor and trans at once.
If you are open to staying with a gen1 SBC, id suggest just doing the LT t56 now. Itll bolt up right to the new motor.
Old Jun 10, 2011 | 11:42 AM
Car: 1986 Iroc
the Lt1 t-56 will bolt to the Lsx? or am I reading it wrong?
and what mods will need to be taken in order to get an Lt1 t-56 behind me engine? I am also considering getting a t5 and just waiting to find an ls and the trans together
Old Jun 10, 2011 | 12:02 PM
Car: '91 LS6/T56/9"
Engine: LS6
The LT1 T56 will NOT bolt to an LS engine, but WILL bolt to any SBC/BBC. So putting an LT1 T56 in your car not is a direct bolt-on. You'd still have to find a pile of parts to do the swap. The other option is to go with an LS T56 now, buy the adapter bellhousing, then you'll be able to use it when you do an LS engine swap. The things you're talking about aren't cheap though.
Old Jun 10, 2011 | 12:26 PM
travis401's Avatar
Car: 91 Camaro RS
The conversion bellhousing will allow an LS t56 to bolt to a gen 1 SBC. however you cant reuse that bellhousing on the LSx motor. the input shaft of the trans would be too far back for it to mate to the LSx motor.
If you do use the conversion bellhousing now, you will need the LS t56, the conversion bellhousing, pedals, clutch, flywheel, and hyraulics from a 3rd gen fbody, a new ls t-56 swap xmember (spohn makes them, i have one with the xmember mounted tq arm), and you will have to cut your drive shaft 2" shorter. And if you dont get a xmember mounted tq arm specific for the LS t56 swap, youll have to cut yours down 2" to mate to the mount on the trans.
When you swap to an LSx motor, you will need to replace the conversion bellhousing for an Ls bellhousing, the clutch, flywheel, pedals, and hydralics from a LS 4th gen fbody, another new xmember, and a new drive shaft (since the one you cut 2" short will be too short now). and if you dont go with a xmember with a mounted tq specific to that xmember, youll need a new tq arm again (since again the one you cut down 2" shorter will be 2" too short now).
Old Jun 10, 2011 | 12:31 PM
travis401's Avatar
Car: 91 Camaro RS
to get an LT t56 behind your 305, all you need is the pedals, clutch, flywheel, and bellhousing and trans from a LT 4th gen fbody. youll need a t-56 swap xmember (again spohn sells them along with other places, or you can make your own) the tq arm you have now will bolt to the tq arm mount on the trans, no mods needed. you will also need to swap to an electric speedo (if yours is mech) or have the t56 tail housing machined for a mech speedo (youll have to do this no matter if its LS or LT t56)
and if you dont swap in an LSx motor and stay gen 1 SBC, all this will work with the new motor.
Old Jun 10, 2011 | 10:59 PM
rippin ron's Avatar
Car: 91 Camaro RS
Axle/Gears: 4.10
The difference in length between the LT and LS T56 is only 5.". That difference comes from the bellhousings having a depth of 4.9" for the LT and 5.5" for the LS. I'm using a LS t56 behind a sbc. I had the input shaft shortened .5" and i'm using Quicktime 8020 bellhousing, with sbc flywheel and clutch.
Old Jun 11, 2011 | 12:34 AM
Car: 1986 Iroc
alright... you guys are quite informative... haha, and Im very thankfull for all your info. so should I try to find a totaled ls car in a junkyard with a working trans and use all it's parts for a swap now? I mean when I pull the trans out, the engine is comming out also. so I plan to rebuild it and mod it just a touch. but yeah, find a junked ls? or would you guys think its easier on me (and my wallet) to get a 3rd gen's t5 for now? once I get my 305 rebuilt and running nicely, Ill be fine with it for a while, so im not in a hurry to get an ls and all the stuff for it. it can wait a while.
Old Jun 11, 2011 | 08:09 AM
travis401's Avatar
Car: 91 Camaro RS
Itll be cheaper to go with the t5. Geting a junkyard ls1 with t56 together isnt gonna be cheap. In general LS swaps arent cheap, you might wanna cruise the LSx swap forum to get an idea of how much is really involved with it.
Old Jun 11, 2011 | 02:54 PM
Car: 1986 Iroc
alright. I believe i may just do the t5 conversion for now. how much should i expect to buy one for? and how much should i sell my 700r4 for? haha, thanks
Old Jun 11, 2011 | 03:06 PM
travis401's Avatar
Car: 91 Camaro RS
good working 700r4 would be about $100-$300, depending on milage. A good used t-5 can be had for $500 for a complete swap (or atleast close to it) setup. they pop up in the classifieds on here from time to time. just for pricing info on the possible LSxswap, theres a wrecked 2000 camaro with 168k miles on the local CL, they want $2000 for it, but its got a running LS1 and t56.
Old Jun 11, 2011 | 04:05 PM
Car: 1986 Iroc
ooooo, where is that ad? and what is the location of your "local"?
Old Jun 11, 2011 | 04:13 PM
travis401's Avatar
Car: 91 Camaro RS
DFW Texas. Even as a 168k mile car, its still a hell of a deal.
Old Jun 11, 2011 | 04:14 PM
travis401's Avatar
Car: 91 Camaro RS
Old Jun 11, 2011 | 04:16 PM
Car: 1986 Iroc
dang it... Im in NC... Id jump on that... but thats a bit out of my way... lol... could you pm me the ad link tho?
Old Jun 11, 2011 | 04:20 PM
travis401's Avatar
Car: 91 Camaro RS
already beat you to the punch on that one
Old Jun 11, 2011 | 04:22 PM
travis401's Avatar
Car: 91 Camaro RS
send me the $2000 and ill go buy it and send you the motor and trans
Old Jun 11, 2011 | 04:25 PM
Car: 1986 Iroc
almost would, but id love to use alot of the interior parts and such in my car, if it really is the good deal it seems to be, ill go trailor it up! haha
Old Jun 11, 2011 | 04:26 PM
travis401's Avatar
Car: 91 Camaro RS
thats what i want out of it...all leather int
Old Jun 11, 2011 | 04:27 PM
Car: 1986 Iroc
yeah... i eventualy want that also... 3rd gen body on an ls everything else...
Old Jun 11, 2011 | 09:30 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If you're going to do a 2.66 / .50 geared T56 w/ the LS_ engine,
do a 3.73 or higher rear first. Then the T56 won't have poor drivability w/ the 305 if you do that swap before the engine.
(even w/ 3.73 drivability isn't great w/ 305 & 2.66 T56 but a compromise rear that will work perfectly w/ the LS_ / T56 later makes a lot of sense to do first.)
Twin_Turbo
Mar 14, 2016 10:10 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
Numbah-1
Sep 12, 2015 08:57 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
tonys91rs
Sep 2, 2015 07:07 PM
