Clutch Doesnt engage / disengage and car shakes / shudders
Ok i have a 1990 305 tbi camaro rs with a 5 speed transmission out of an 87 camaro rs. Engine is not stock.
Then engine is a 350tbi out of a 1994 silverado vin k.
Just recently the clutch started slipping so i replaced the clutch, pressure plate, pilot bearing, throwout bearing, and the flywheel set up for a stock 1990 camaro rs 305 tbi.
the pressure plate and clutch are oem replacement and the flywheel is an oem replacement reman (thats my guess on the flywheel since it was a 100$ core charge nothing else.)
When i put these parts in and put them in correctly. the transmission would not shift through the gears even using the clutch. I could start the car in gear but the it would not come out of gear by using the clutch pedal either.
I figured it would be the slave cylinder due to noticing what looking like brake fluid where the rod rests in the slave cylinder. replaced and tried again with same result. Changed the master cylinder just in case it was bad due to it being old since it looked like the original one. Same result even after excessive bleeding. the rod pushes the clutch fork 1/2 inches which i have been told is a good operating length. Please help. I do not know what is wrong or could be wrong. I dont know if it could be the flywheel due to it not being stock for a 94 silverado or if its just faulty parts. Please give me any insight possible. (ps. if driven car will start in gear but has a slight push as if clutch is not in all the way and if on a hill will not roll when the car has the clutch pushed in.)
Car: 84' trans am
Engine: 305 h.o
Re: Clutch Doesnt engage / disengage and car shakes / shudders
I'm Having the same problem now but after putting a f1 flywheel stage 3 clutch n t56. The only way to fix it is to make you MC adjustable or buy an adjustable MC to give you more throw/extension. If u Move the slave cylinder etc the hydraulics will compensate and it wont fix the problem.
http://m.ls1tech.com/forums/showthread.php?t=317767
Shows u how to mod your MC making it adjustable hope this info helps
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 11, 2015 10:11 PM
novaderrik
Aug 10, 2015 12:44 PM
rsrmoore
Aug 7, 2015 08:44 PM
