5500 rpm shifting???
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i got an annoying problem! my 85' iroc 700r4 is shifting crazy... when i go from park to drive i get a noticable jerk... then the car drags or should i say takes its time getting up to speed, it will rev real high to about 5500 and then another jerk then i m up spd in a seconds and the rpm drops to normal...its easy to spin the wheels when doing sometimes too..the car only has 78,000 on it when i bought it last year...
could the prev owner did something to make the car shift like this? stall converter, shift kit, etc... i need help, i cant drive arouond like this all summer.....thanks guys ( and gals....)
Re: 5500 rpm shifting???
Are you saying that when you drive normally, it will not shift till you get to 5,500rpm? If this is the case, then the governor gear is most likely broke. The 1982 - 1986 transmissions do not have a smooth park or neutral to drive engagement. The 1987 & up units have a forward accumulator which makes the park or neutral to drive engagement much smoother.
Car: 1983 G20 Chevy
Transmission: 4L60
Smooth isn't in the early 700r4s vocabulary, it is downright harsh, atleast the one in my 83 was. Wish they never would have junked that case when I had a shop rebuild it. Van has never felt the way it orignally did since. The stock WOT shifts in the 83 were around 5,300 rpm and the replacement shifted around 4,200.
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
Thats exactly whats happening.. it wont accelerate until i push it to 5500... then it moves easy...
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
And if i come to a stop light.. it does it all over again... real sluggish til it reaches 5500 then i feel a shift and it gooes with tires spinning...
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
It does this in d1 and d2, havent tried 2nd or 3rd yet....
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Have you checked your TV cable? Governor? Those are the two most obvious things to look at. If the clip for the cable breaks, the trans will go to full line pressure, and shift real harsh. If the teeth on the governor strip, it will essentially be stuck in first gear.
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
Anyone got pictures and can tell me the correct way to fix it?
Car: 88 Camaro SC
Engine: SFI'd 350
Heres a pic of my TBI (not carb, but its the best I have) showing the TV cable. Its the thing highlighted. Check to make sure that the plastic clip hasnt broken off. Youll be able to tell because the cable will just be dangling there.
Also, open the throttle all the way up, and check to see if the cable has slack. it should be nearly taught with no slack. If the clip is broken or breaks, most transmission shops have them in stock. I think some autoparts stores may have them as well. The one they have just slips onto the cable, and clips in the same place the old one did.
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok thnx, ill check that, does anyone have a pic of the "govener" or the part that connects to trans??
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i got some pics, can someone tell me if this way too much slack??
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i took these pics with the car off, im getting like 1 inch slack in both directions... got up under the car but quite see the govner...
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
MikkoV
Sep 9, 2015 04:25 PM
