89 GTA - getting "bang bang bang" from rear on hard lauch
Old Jun 13, 2011 | 06:57 PM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I have an 89 GTA, L98 and lately I've noticed if I launch hard I get this banging from the rear. (harder I launch, I get more rapid bangs about the same interval apart)
I jacked up the car and everything appears ok. I recently replaced the trans mount. I can't tell if it's internal to the rear of part of the suspension but the car is find if I keep off the gas.
Any suggestions?
thanks,
-Dan
Old Jun 13, 2011 | 11:47 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: 89 GTA - getting "bang bang bang" from rear on hard lauch
Are the torque arm bolts tight? Do you have a drive shaft loop maybe hitting the weights on the drive shaft. If all that is good, you may want to pull the diff cover and see if you have any missing teeth on the ring or the pinon gear.
Old Jun 14, 2011 | 12:10 PM
Car: 89 GTA
Transmission: 7004R
I was wondering if it could be a worn posi. My posi hasn't been working for a while now but the only syptom was 1 wheel spin. I was wondering if the "skipping banging" I'm getting is the posi trying to work.
The rear is quiet when I'm not on it so I was thinking bad teeth would make some noise. No drive shaft loop and I guess something could be loose but those parts have never been apart.
Old Jun 14, 2011 | 02:05 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Its possible, maybe a spider gear is missing a tooth, or coming apart.
Jack the rear of the car up again, and spin one wheel with the car in park, (or gear if its a stick) and see if you have any noise. If so, may be time for new spiders or a new carrier.
I'd pull the cover though and look for chunks in the fluid, or obvious damage.
Old Jun 14, 2011 | 06:36 PM
calroc's Avatar
Check carefully where the torque arm bolts to the rearend housing. Either that end of your torque arm, or the bolt mounts on the rearend may be broken. Under hard acceleration, or launching it will make the whole rearend want to rotate clockwise along with the wheels. The end of your driveshaft & pinion (at the u-joints) will bang in the top of the tunnel.
Old Jun 14, 2011 | 07:20 PM
Car: 89 GTA
Transmission: 7004R
thanks, I'll post when I have time to investigate.
Old Jul 5, 2012 | 06:32 PM
Car: 89 GTA
Transmission: 7004R
Car is back on the road after a complete rear diff swap - only took me a year ;-)
New (used) rear posi hooks up great but same exact rapid banging on hard launches. Any thoughts? (I replaced rear shocks and complete diff off another third gen car)
It is coming from the rear for sure and it almost feels like a hop or skip
Old Jul 5, 2012 | 07:23 PM
Wheel hop?
Old Jul 5, 2012 | 08:07 PM
Car: 89 GTA
Transmission: 7004R
Wheel hop?
could be but there does seem to be a bang from the rear when it happens
I think I ruled out the axle, rear, etc by replacing it and all the torques are corrrect.
maybe bushings - nothing looked obviously wrong except there was a diagonal arm which was bent that i straighened out - the arm attached from the drivers side of the axle housing to the passenger side of the body - no idea how that got bent
Old Jul 5, 2012 | 08:31 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
you may need lower control arm relocation brackets
Old Jul 5, 2012 | 08:55 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
The banging is the trans mount or the mount where your torque arm meets the trans. Mine did the same thing when I gassed it years ago when I first bought it. The bolts had fallen out of the trans mount allowing the torque arm to hit the trans tunnel. It only did it when I gassed it very hard or when it went into passing gear.
Old Jul 6, 2012 | 03:51 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
+1 that's what happened to me years ago
Old Jul 6, 2012 | 05:02 PM
69-er's Avatar
Mine's doing the same thing. Where can I get the trans rubber mount? Mines shot!
Old Jul 6, 2012 | 07:55 PM
OrangeBird's Avatar
Car: 1989 Firebird
Have you checked the driveshaft slip yoke that plugs into the trans ? I've had one of those malfunction and make the exact noise you describe . Mine finally got bad enough to be readily evident , and the fix was a rebuilt trans with a new slip yoke . Under moderatly high power it would bang as the splines couldn't hold the torque , and it sure as heck sounded like it came from the back of the car . The sound probablly followed the driveshaft and appeared loudest from the back .........
Old Jul 6, 2012 | 08:48 PM
69-er's Avatar
OK, I found them on GMpartsdirect.
Old Jul 15, 2012 | 05:27 PM
Car: 89 GTA
Transmission: 7004R
I guess I need to pull the driveshaft to check this? does the yoke pull out without opening up the trans? Really hope it isn't something IN the trans.
I was just under the car again - all looks good. all bolts torqued. No signs of anything making contact with something it shouldn't. And problem is identical before complete diff swap.
So I can believe this could be the problem. Bumps from rear seem to correlate to how hard i am hooking up. I usually get 2 to 3 bumps for launch or one hard one for a downshift.
Thanks for the suggestions
LilHot
South Central
Apr 13, 2026 11:46 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
