mosser 9"?
Old Jun 17, 2011 | 12:34 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
mosser 9"?
i was looking for somthing a bit stronger than a factory axle and i found the mosser 9" my question is there is an option between detroit locker and trutrac posi which of these provides good street response for normal driving like the factory axle but good drag response?
Old Jun 17, 2011 | 12:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: mosser 9"?
trutrac is a posi that acts more like stock stuff. The locker is NOT recommended for turning My buddy had one and it is loud around turns, clicking and such. Almost like its binding up. Its designed to lock up both axles so in turns one tire cannot spin faster than the other like it should.
I'd go for a trutrac
Old Jun 17, 2011 | 02:39 PM
Red 87 GTA's Avatar
Re: mosser 9"?
trutrac will lock both in hard launch and dragging though correct?
Old Jun 17, 2011 | 04:50 PM
Maria8's Avatar
Car: 1985 Pontiac Trans-Am
Engine: AFR 235,Dart 400 Procharger F2. EFI
Transmission: Coan 400 + Gearvendors
Axle/Gears: racecraft 9"
Re: mosser 9"?
I had a detroit locker in my 9" for years. Mine was not loud, maybe I tolerated a lot more than most. I used it for 25,000 miles with no issues. Yes, it is a little harsh at times. Like when you start throwing power at it, it sways you to the left a small amount then to the right on deceleration, but only once in a while. I ran it from a 13 second car till I got 9.30's. I never worried about it breaking. It works great and you wont regret using it if you want serious traction. Do your homework on how it works, it may be too radical for you, but only you can decide what you want and can live with. Good luck
Old Jun 17, 2011 | 06:50 PM
Red 87 GTA's Avatar
Re: mosser 9"?
well i basically need something stronger because im in that 420ish ft pds of torque with my rebuild and i put in a level 10 pts 200r4 trans so thats just next in line to replace but i also plan to do a little road racing/ short circuit stuff along with draging it so i need something that is the best well rounded.
Old Jun 18, 2011 | 04:44 AM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: mosser 9"?
I have a locker in my car and have had not ptoblem with it on the street, had one in my chevelle which \I ran for years on the street making 750 hp, I never found them noisey at all. A locker is my choice, especially if you have a car with any power
Old Jun 18, 2011 | 07:46 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: mosser 9"?
From my understanding from talking to Quick Performance about there 9"s.
Locker provides posi, but it tends to be a little louder and harsher when it locks up and unlocks.
True-trac is also a posi, but it uses gear type drive and will lockup and unlock without the noise and harshness. They said they are low maintenace and recommended for daily drivers.
At a point everythings a trade off you just need to decide which direction you plan on going and go with it.
Old Jun 18, 2011 | 07:57 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: mosser 9"?
I've been running a Detriot Tru-Trac for about 4 years now. I can't claim near 750HP, but I get a respectable 495 ftlbs at the wheels, and no issues. If I have any complaints about them at all, it's that they seem to want to stay posi and squeel the rear tires a bit if you apply power while turning at times.
Old Jun 19, 2011 | 06:15 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: mosser 9"?
have been running a det locker for years.. not a peep from it on the street or track..
mine was set up by guys who do them for a living..(curri entps)
love mine. get one set up by guys who do them for a Living.
Old Jun 19, 2011 | 08:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: mosser 9"?
If you really want a good diff, look into the wavetrac stuff...expensive but well worth it from all the reviews i've heard, including some local racers i know. I am likely going in that direction once I blow this 10 bolt....
tkrupinski
Jun 14, 2010 04:01 AM
iroc.86
Feb 8, 2008 02:36 PM
drperformance
Jul 10, 2006 11:23 PM
