Transpak kit/shift improver......
Old Jun 27, 2011 | 07:56 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Under product line it lists these. What is the difference between the two? Both say shift kits and Transpak on the box in the pic.
Transpak - http://www.summitracing.com/parts/BMM-70235/
Improver - http://www.summitracing.com/parts/BMM-70239/
Old Jun 27, 2011 | 08:06 PM
Guest
Guest
Posts: n/a
Re: Transpak kit/shift improver......
The Pak costs more because it includes more stuff, to give you more options and more control. If you just want the tires to scream when you go to second at full throttle, then you don't need the Pak.
Old Jun 27, 2011 | 08:14 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
The Transgo kit is better that's just me.
Old Jun 28, 2011 | 02:16 PM
Pro Built Automatics's Avatar
The TransGo Shift kit is the "only" way to go here. The B&M is very hard on the gear train, and I would never recommend it.
Old Jun 30, 2011 | 10:58 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
X2 for the transgo. The cheap B&M kit simply gives you spacers to block the travel of the 1-2 and 3-4 accumulators, along with a stiffer pressure regulator spring,a couple shift valve springs, and tells you to drill out a couple shift feed passages in the separator plate. It includes nothing for the 2-3 shift, it will not make it shift into 3rd any harder. For that, the transgo kit includes a stiffer spring that installs in the servo, which is where the 2-3 accumulator spring it located. It also retains accumulation for the 1-2 which in my opinion is the better way to do it than simply jamming the piston from moving at all. Plus the transgo kit comes with a bigger boost valve, and reverse boost valve which are nice to have as well. Give Dana a call or check out his website. www.700r4l60e.com I'm building a 700r4 with one of his rebuild kits right now, he's a good guy to deal with.
TomTPI
Apr 6, 2006 03:55 AM
91greenbird
Feb 5, 2006 08:23 AM
Josh 91RS
Jan 11, 2001 08:04 PM
FastBroker
Oct 14, 2000 09:32 PM
