T56 Speedo cable mod
Old Jun 27, 2011 | 08:20 PM
Jeff14R's Avatar
Car: 86 IROC
Engine: 383ci
I had alloy from the board here do my T56 tail-housing modification to use my cable drive for the speedo.
I just wanted to give him some credit on the job well done and promptness of the turn around.
Great job alloy!
Old Jun 28, 2011 | 11:41 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: T56 Speedo cable mod
Got more info on this? Never heard of someone doing this besides the jagsthatrun company that used to do it.
Pic's and price would be nice thanks!
Old Jun 28, 2011 | 07:33 PM
Jeff14R's Avatar
Car: 86 IROC
Engine: 383ci
I will let alloy handle this. I don't want to do anything he might not be ok with. You can look him up and send him a message.
Old Jun 28, 2011 | 08:27 PM
Guest
Guest
Posts: n/a
Why not just order the retrofit version of the T56 that Tremec intends for our cars? It comes with the speedometer gears.
Old Jun 28, 2011 | 08:39 PM
BEcause it costs about 4 times as much as a junkyard LT1 one.
And STILL isn't a bolt-in.
Old Jun 28, 2011 | 10:30 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 2.97 geared version is weaker than the 2.66 version.
The driveshaft needs shortened.
It has less overdrive (a major T56 advantage over the T5 is the wider overall ratio spread; the aftermarket version lacks this.)
Due to the pre-T56 bellhousing + adapter plate putting more length up front, it is harder to fit in earlier chassis cars (not third-gens) and weighs more.
Old Jun 29, 2011 | 08:26 PM
Jeff14R's Avatar
Car: 86 IROC
Engine: 383ci
And of course the most obvious...you already own a T56.
Old Jul 2, 2011 | 10:36 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Tony89GTA,
I'm heading off for work now but I'll pm you later with pics and pricing on the cable mod.
Thanks for the kudo's Jeff. Was a pleasure doing business with you.
Dan
wigmobile
Feb 26, 2025 02:56 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
camaro1185
Oct 26, 2015 06:51 AM
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 7, 2015 05:22 PM
