Thinking of getting one, anybody have cons about them? If so, why? Where would be the best reasonable price be found?
only possible con would be slightly less durable than a steel one, other than that, they are better. The 3rd gen aluminum shafts are smaller in diameter than the 4th gen ones, but are thicker.
ebay or classifieds or craigslist or something like that.
4th gen ones will bolt right in, but are a little shorter.
4th gen LS1 type have dampner built into the front yoke. Make sure you get a straight one without any dents or cracks if you get a used one.
cons: Not as strong as a good steel shaft. Factory aluminum driveshafts are nothing like an aftermarket aluminum driveshaft. They're actually very thin and weak.
If you can find a good one for about a $100, go for it. Not a big performance upgrade, but it looks better then that rusted piece of crap.
well it takes a little less to damage an aluminum one over steel but I really dont see any cons otherwise
jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:94 Times in 91 Posts
Quote:
Yep. A friend ran a third gen alum. shaft in a 10 second car with no issues. That's more of a problem with the later cardboard damped ones.Originally Posted by //<86TA>\\
only possible con would be slightly less durable than a steel one, other than that, they are better. The 3rd gen aluminum shafts are smaller in diameter than the 4th gen ones, but are thicker. So unless the OP is going to drive a rallye on a rocky road, alum. is a better choice.
a new one on the order of 300-400 dollars, a used one should be in the 50-150.
hellz_wings
close
I bought a new Inland Empire 3" aluminum driveshaft and the thing is very beefy. The thing is rated to go to very fast and take alot of HP abuse. No vibrations at high speed either.
http://www.jegs.com/i/Inland-Empire/...oductId=752595
Yup Inland and Denny's are most people first choices.
Quote:
Originally Posted by UnderCover89TBI
Yup Inland and Denny's are most people first choices. My first choice was a 1LE used one for $100. If I had to spend that much for the above ones my old steel dr shaft would still be on the car.
Yeah I meant thier first choice for aftermarket ones, I wouldnt have one unless I found the 1LE one I have in my car now. 30 bucks yo! haha.
Quote:
Yo! haha... But I had mine for the last 12 years. Also it was in almost brand new condition at that time. My opinion was, no one should spend over $100 for a 1LE/LS1 aluminum shaft now.Originally Posted by UnderCover89TBI
Yeah I meant thier first choice for aftermarket ones, I wouldnt have one unless I found the 1LE one I have in my car now. 30 bucks yo! haha. hellz_wings
close
the aftermarket ones are stronger though.. but i guess it's overkill for me personally, but if you're not making more power than an LS1/6 then you should be fine.
So the 4th gen DS are the same length, and I will not have an issue? Is the yoke the same? Plug & play.
I am keeping my eye out on ebay. Here is one...
http://cgi.ebay.com/ebaymotors/93-02...Q5fAccessories
Originally Posted by xX89RSXx
So the 4th gen DS are the same length, and I will not have an issue? Is the yoke the same? Plug & play.I am keeping my eye out on ebay. Here is one...
Yes...3rd gen 1LE ad 4th gen 1LE/LS1 aluminum dr shafts will fit V8 cars with Auto/Manual.
The only problem i have seen is strength but it definently was dented first
Forgot pic
Forgot pic
the actual 3rd gens one are stronger, but the 4th gens ones are easier to find. You'd be fine with either id say. I mean unless your making 450 RWHP then you might wanna step up to an aftermarket one.
Quote:
Forgot pic
I think I have seen this picture before. All I have to say is DAMN! How much HP were you pushing? What did it feel like when it happened?Originally Posted by keeslinger31
Forgot pic
yeah I shudder to think about something failing that catastrophically on my own car, lol. That thing is twisted as hell, looks like it was nothing but a rolled up tube of cardboard to that engine.
It wasnt me but a post on here somewhere i just remember saving the pic cause it was so amazing. But the person dumped the clutch in gear and killed it resulting in the twisted heap
hellz_wings
close
atleast it's still in one piece lol
Quote:
I'll give it credit for that haha Tags 1992, 305, 4th, aluminum, body, camaro, downside, drive, driveshaft, driveshaftdents, fourth, gen, generation, performance, shaft
