replaced the trans and now speedo is 20 mph off
Old Jul 7, 2011 | 06:21 AM
Dusk2600's Avatar
Car: 85 z28,01 sonoma,05 envoy
Engine: 305 tpi
Transmission: 700 r4
Axle/Gears: stock
if i do 60, it reads 80, i only swapped transmissions. 700r4 to a 700r4, worked fine before the swap, any ideas guys?
the gear on the transmission shaft was the same as mine, we swapped the housing cus mine is not electronic the new one was, caprice tranny.
Old Jul 7, 2011 | 06:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: replaced the trans and now speedo is 20 mph off
So both the drive and driven gears in the new trans were the same as the old?
JamesC
Old Jul 7, 2011 | 07:35 AM
Dusk2600's Avatar
Engine: 305 tpi
Axle/Gears: stock
i would think so, both same transmission, i know the gear on the shaft was identical.
Old Jul 7, 2011 | 07:44 AM
JamesC's Avatar
Transmissions have different drive and driven gear combinations to accommodate the rear end ratio. I suggest you verify that the drive gear is the same. Perhaps the following will be helpful:
https://www.thirdgen.org/forums/tran...eedometer.html
JamesC
Old Jul 7, 2011 | 09:17 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Nope.
When the speedometer, speedometer cable, driven gear housing sleeve and driven gear are all the same but the speedo now reads differently, it's impossible for the drive gear in the trans. to be the same.
It would have been easier to swap that gear before you rushed to get the new trans. in.
The Camaro one might be a 15 tooth. The Caprice one is probably 17; maybe 18 tooth.
Old Jul 7, 2011 | 09:51 AM
Dusk2600's Avatar
Engine: 305 tpi
Axle/Gears: stock
both gears on the tailshaft were green, possible something inside is different?
Old Jul 7, 2011 | 10:04 AM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
there is nothing different inside.the two gears are the only thing that sets your speedo.the tooth count must be different, regardless of the color.
Old Jul 7, 2011 | 10:39 AM
JamesC's Avatar
This from the link I provide above:
"Beware that both 34 tooth and 42 tooth are both green."
JamesC
Old Jul 7, 2011 | 12:43 PM
Dusk2600's Avatar
Engine: 305 tpi
Axle/Gears: stock
hecounted the teeth, perhaps miscounted? so can the old one be taken off?
Old Jul 7, 2011 | 12:45 PM
Dusk2600's Avatar
Engine: 305 tpi
Axle/Gears: stock
thanks for all of the replies too...
Old Jul 7, 2011 | 01:24 PM
JamesC's Avatar
Post #9 of the above link. Good luck with your project.
JamesC
Old Jul 7, 2011 | 03:22 PM
jmd's Avatar
jmd
Jack, the rear up on stands, put the trans. in neutral, mark the gear in there w/ a sharpie and count the teeth.
You swapped the trans. so you can do the gear swap. This time, once the tq. arm & driveshaft are dropped and the trans. is off the crossmember and drooping, unbolt the tail and once that's off, work the gear past the clip. It's easy, all things considered.
Jorlain
Aug 24, 2022 05:11 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Irocohio
Aug 12, 2015 08:03 AM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
