What will easily replace a th350?
Old Jul 9, 2011 | 12:07 AM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
I have a, 305 carb, auto th350 3speed with overdrive. Looking for more gears, what will easily bolt up that will give me more gears?
Old Jul 9, 2011 | 06:00 AM
Re: What will easily replace a th350?
The 350 doesn't have overdrive.
What do you have; a 350, or a trans with overdrive? Identify it properly first, and go from there.
http://www.bulkpart.com/Merchant2/me...General-Motors
Go here for easy pan identification pictures.
Old Jul 9, 2011 | 06:43 PM
Car: White 84 z28
Engine: Chevy 350
Uhhhh. It's a 3 speed with lockup? Deffinate 3 and something more that doesn't feel like full gear. From that like I think it's a 350c? Could be wrong
Old Jul 9, 2011 | 06:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your choices are a 700R4 or a 200-4R.
Old Jul 10, 2011 | 08:15 AM
Could be wrong
Sure; we all could.
No point in arguing back with us about your confusion and uncertainty.
When you looked at your pan and compared it to the ones on the page, what did it turn that you actually have?
Old Jul 12, 2011 | 10:08 AM
Guest
Guest
Posts: n/a
Doesn't matter if it's a 350c, a 250c or a 200c.
The 200-4R swap allows retaining the current driveshaft, but requires custom mounting. The 700R-4 can be done with all stock parts, you just need to find a good donor car.
Old Jul 12, 2011 | 12:18 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if its the stock 87 transmission, you've got a 700r4. someone could have replaced the transmission before you, in that case you need to check out the link provided to identify the which one you've got.
as for direct drop in, you're not going to find a 5 or 6 speed that'll work without a lot of fabbing and money
Old Jul 12, 2011 | 12:35 PM
I'd lay 1000-to-1 odds that he has a 700.
But until he GOES OUT AND LOOKS, and then tells us WHAT'S ACTUALLY THERE, there probably isn't alot we can do to help him any further.
Jeremys87
Jul 14, 2022 09:08 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Fronzizzle
Aug 9, 2015 01:15 PM
