manual swap pedals
Old Jul 13, 2011 | 10:05 PM
problem2420's Avatar
Car: 86 ta
Engine: 305tpi
Transmission: t5
Axle/Gears: 2:77 soon to be 3:42
manual swap pedals
i just got these pedals but there missing a few things? i was wondering if i could be told what they were. and i out the two automatic brake switches were the manual ones were, is that okay? is there supposed to be one for the clutch? also what do the purple and green wires splice in. thanks guys
Old Jul 14, 2011 | 04:14 AM
Re: manual swap pedals
is that okay
Should be. Brakes are the same no matter which method the trans uses to change gears.
Yes; actually there should be 2. One should go in a hole in the bracket, and look ALOT like the one in your hand that has a vacuum line on it; that one is for the cruise control, and disengages that when the clutch is pushed, just like the brake does.
The thing the purple & green wires are hooked to looks like it might be the starter safety switch for the clutch (only lets the car start if the clutch is to the floor).
1992 Trans Am
May 10, 2023 07:19 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
