Rough Vibrations! Need Help!
Old Jul 16, 2011 | 04:16 PM
travis88iroc's Avatar
Car: Chevy Camaro IROC-Z
Engine: 5.7 350 c.i.
Axle/Gears: 9-bolt 3.70 ratio posi
Today i had replaced the transmission mount and crossmember(the old mount separated) w/ a Energy Suspension mount and UMI crossmember. Everything went in fine, raised the tranny a little bit to get room and swapped in stuff and was good.
So i took it for a drive and now there are vibrations at higher RPMs right before every shift! The fly wheel does have a few teeth chewed up so could it be my flywheel(always been chewed up)? Did i lift the tranny up too far? When i raised tranny a lil, did starter come off flywheel a lil bit? The vibrations had just begun after replacing the member n mount! Is my daily driver, work alot so dont have time to take it to performance shop!
So what is calling these vibrations??? Please help.
Old Jul 16, 2011 | 04:34 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Rough Vibrations! Need Help!
There has been issues sometimes from installing the ploy mounts and viberations. If you search you should them.
Old Jul 16, 2011 | 04:40 PM
i have read where the Energy Suspension mount raises the tranny a bit and could cause the pinion gear to change angle. But why would an poly mount cause vibrations?
Old Jul 16, 2011 | 05:01 PM
Engine: 383 SBC
More extreme angles on the u joints probably. You could try sawpping back to rubber mount and check for vibrations.
Old Jul 16, 2011 | 05:04 PM
I will try that, thanks! Do you know of any good brands?
Old Jul 16, 2011 | 08:33 PM
Engine: 383 SBC
Stock replacement from Autozone worked for me.
Old Jul 17, 2011 | 01:33 PM
Thanks! That's what is was, was that Energy mount! Switched back to stock rubber(dont like it) mount, and it stopped all vibrations! Thank You!
Old Jul 17, 2011 | 01:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
In case other members are searching for similar problems, check below for a comparison of mounts:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
69GTOby
Apr 18, 2016 02:34 PM
Reid Fleming
Oct 10, 2015 09:56 PM
drumstixer
Sep 29, 2015 03:02 PM
Jlanz55
Sep 29, 2015 08:55 AM
roysatikas
Sep 22, 2015 08:15 PM
