Will these 3.73's fit my 305 tbi
Old Jul 24, 2011 | 05:49 PM
DrexRS's Avatar
Engine: 305 TBI
Transmission: 5 Speed Manual Transmission
Axle/Gears: Stock
I want to get some rear end gears.
I found some cheap on ebay would these fit? http://compare.ebay.com/like/1606047...=sbar&_lwgsi=y
Old Jul 24, 2011 | 06:58 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Will these 3.73's fit my 305 tbi
As long as your '88 TA has an 82-02 10-bolt rear, yeah.
You'll need to change the speedo gear on the vss (maybe the one in the trans. too) so you have correct speedo reading.
The description:
This is a 3.73 gear ratio, only works with a 10-bolt 7.5 (7 1/2") or 7.625 (7 5/8") 3-series carrier. This can be used with a 2-series carrier only if you install a ring gear spacer and longer ring gear bolts (not included). Most 93 and newer applications require PCM reprogramming if changing the gear ratio. Fits the following applications:
82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92 Camaro, RS, Z28, IROC-Z with a 10-bolt rear differential
82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92 Firebird, Formula, Trans Am, GTA with a 10-bolt rear differential
93, 94, 95, 96, 97, 98, 99, 00, 01, 02 Camaro, RS, Z28
93, 94, 95, 96, 97, 98, 99, 00, 01, 02 Firebird, Formula, Trans Am
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
