please help with lock up converter kit.. something not right
Old Aug 3, 2011 | 10:58 AM
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
700r4 trans. i bought this from friend with a fresh rebuild and never installed. the shop told him all he had to do was hook up a power lead to the red wire coming out of the trans. so i ran a wire from my fuse box to a toggle on my dash to the wire on the trans. drive the car and 1sr through 3rd feel great but no 4th/overdrive. pplleeaasseee help i'm pulling my hair out on this.
Old Aug 3, 2011 | 05:17 PM
Guest
Guest
Posts: n/a
Re: please help with lock up converter kit.. something not right
Converter lock is a separate issue from no OD. It may be something as simple as the seal around the 4th apply piston being on backwards.
GM designed the 700R-4 to be able to have converter lock in second and third gears as well as in OD. Just make sure it unlocks before each upshift or downshift.
Old Aug 3, 2011 | 05:39 PM
89fbrestor's Avatar
you i was easily lost with that comment lol so basically take it to a shop and let them figure it out lol. i was told i might have the wrong voltage/amperage wire going the lead out of the trans. i'm guessing i would probably just be safer having a pro look at it thanks ronn for the input all the same.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
