Will limmited slip leave two lines?
Old Aug 3, 2011 | 01:59 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
If you have limmited slip/posi will it leave two lines when you burn out? I thought i heard that it would but want to be sure. Thanks
Old Aug 3, 2011 | 02:11 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Will limmited slip leave two lines?
Yes if it's working.
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes, if the limited slip is functioning correctly.
JamesC
Old Aug 3, 2011 | 02:41 PM
Car: White 84 z28
Engine: Chevy 350
If its working? So im assuming thats something that wearss out or brakes. How often does that happen? And im guessing the only fix is to complete replace with new kit
Old Aug 3, 2011 | 02:46 PM
JamesC's Avatar
I assume you have a 9-bolt. If so, the following will be an interesting read:
https://www.thirdgen.org/forums/faq-...now-about.html
JamesC
Old Aug 3, 2011 | 02:53 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Yes. The internals can wear out, break or need re-adjusting. Depends on how hard/often it's used and your luck.
billybob6110
Sep 23, 2015 01:30 PM
snakeshooter
Sep 7, 2015 11:13 AM
TBRays98
Sep 6, 2015 05:05 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
