rear end help
Old Aug 8, 2011 | 01:58 AM
affliction1's Avatar
Car: 89 chevy camaro rs
rear end help
my 89 has an unknown rear in it and the only break pads i can use are the front ones after i wear them down half way,i can switch them to the back and they work,besides that no break pads will work,also when i do switch front to back the pads still drag a little on the rotor
Old Aug 8, 2011 | 06:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end help
Originally Posted by affliction1
my 89 has an unknown rear in it....
Only two types of braking systems: iron Delco-Moraine calipers with 10.5" rotors (82-88) and alum PBR calipers with 11.7" rotors (89-92). Purchase the appropriate pads. There'll always be a bit of a drag.
You can see what PBR's look like in my vbGarage (icon next to my online status).
JamesC
Old Aug 8, 2011 | 07:02 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: rear end help
1989 + PBR rear brakes
Old Aug 8, 2011 | 07:49 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: rear end help
JamesC
Did the disc brake 10-bolts have the same brake calipers on them?
Old Aug 8, 2011 | 07:57 AM
JamesC's Avatar
Re: rear end help
Though the backing plates are different, the brake systems themselves are the same, 9- or 10-bolt.
JamesC
Old Aug 8, 2011 | 09:41 AM
Guest
Guest
Posts: n/a
Re: rear end help
Someone may have swapped an older axle into that car. My '84 rear pads aren't so different from my fronts.
And when I recently replaced the right rear rotor, I had to use channel lock pliers to twist the caliper in.
Old Aug 8, 2011 | 10:20 AM
Re: rear end help
my rear breaks are the same as the front,just seems like either the rotor is to wide or caliper pistons dont open far enough
Old Aug 8, 2011 | 10:48 AM
JamesC's Avatar
Re: rear end help
If you have the Delco-Moraines, note that the pistons screw back in as ronnjonn mentions (they don't press in with a C-clamp like they would in PBR's), so your issue may lie there. Autozone should have the tool--or you can use a set of needle nose pliers.
JamesC
Old Aug 8, 2011 | 03:40 PM
Guest
Guest
Posts: n/a
Re: rear end help
The moraine calipers require regular use of the hand-brake to keep them from seizing up.
Old Aug 8, 2011 | 03:48 PM
JamesC's Avatar
Re: rear end help
And even the above may not be sufficient. For those who haven't seen it, here's the recall:
http://members.shaw.ca/crussel/recalls/86c28/86c28.html
JamesC
Old Aug 8, 2011 | 04:47 PM
Car: GTA
Re: rear end help
I have Moraines & an Automatic so I don't use my e-brake regularly like the T5 guys do. I can't remember the last time I pulled my e-brake, yet my brakes work. I can put it on jackstands & the brakes easily stop the rear tires. I've locked up all 4 breaks at 65mph. Maybe I have the ONLY Moraines in existence that actually work?
I had a rear bleeder leak all the rear fluid out of the master & that was 1 scary ride going to get a new bleeder & to where I could get a 2nd person to help bleed the brakes. Yeah, I shoulda just bought Speed Bleeders but didn't.
Old Aug 8, 2011 | 09:38 PM
Re: rear end help
anyone got a pic of what i have to twist to ajust the brakes?or step by step on how to do it
Old Aug 9, 2011 | 08:58 AM
Guest
Guest
Posts: n/a
Re: rear end help
You twist the piston itself.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
