Anyone use a spool?
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Anyone use a spool?
Anyone have a spool installed in their rear and drive to and from the strip with it? Or occasional street driving? I'm just wondering what the manners of the car would be while driving with one.Obviously you wouldn't be doing any high speed turning with one but generally how does it affect the manners of the car?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Anyone use a spool?
a spool in the stock 7.5" rear is a bomb waiting to happen you will break parts pretty quick since these rears are pretty weak as they are.
Short and dirty answer, dont waste your time.
Car: 1985 Z28
If I upgraded to a 9" or if at all possible a gm 12 bolt,Overall I'm just curious as to how the car will act for ocasional street driving.As far as chirping around turns and such.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
How a differential works
http://www.youtube.com/watch?v=K4JhruinbWc
Skip ahead to where they start explaining locked axles.
Car: '82 Z28
I run a 9 inch with a spool and yes, drive it on the street once in a while. Drives pretty normal, tends to dart around a little bit over rough roads, parking lot driving I try to take a wide turn when I can. Driving in the rain feels no different than when it had just a posi. My 4x4 chirps it's tires more than my car which only does it if I have to turn sharp into a parking spot. Never once have heard it chirp making a right turn on the road. This is all very limited street driving like maybe 100 miles a year now a days.
Car: 1985 Z28
Very helpful,Thanks!
darwinprice
17
Oct 11, 2015 11:51 PM
red90IROCls1
Aug 25, 2015 06:56 AM
