Who makes a TKO600 conversion for thirdgen cars?
Old Feb 7, 2013 | 08:45 AM
  #51
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Who makes a TKO600 conversion for thirdgen cars?
Bringing this back, i didn't realize they made a plate now, has anyone else had this problem? i'm using the standard adapter, i don't have any issues yet, it seems that the adapter should be enough to hold the bearing... this would suck to pull the tranny to install a plate...
Old Feb 7, 2013 | 10:10 AM
  #52
86Z's Avatar
86Z
Car: 1986 Camaro SC
i just talked to fortes, he's going to send me the plate, the tko500 has the retainer installed from the inside, the 600 is installed from the outside which will flex under load not supported. i'm not removing my trans though, i'm just going to cut the plate and sandwich it in there.
Old Feb 7, 2013 | 11:44 AM
  #53
topless87's Avatar
Car: 1987 IROC-Z Convertable
Transmission: 5 Speed BW T-5
Axle/Gears: 3.08 Posi
Here is a picture of the complete "kit" to install the TKO's into a 3rd gen. Notice how the "shim plate" will sandwich between the adaptor and the trans to keep the bearing from working out. Has worked great for a year now and it has been ran hard. Anymore questions, just ask and I will tell you what we did if you haven't already been through it.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
Exxon Limited
Aug 9, 2015 08:13 PM
