350 to a T5
Old Sep 2, 2011 | 04:35 PM
kyle7148's Avatar
350 to a T5
Hi, new to the site here, and i have found some good informational articles.
Any way, I am in the process of putting a 350 in my 92' firebird, the problem im having now is that i cant find a flywheel to fit the 350 and still be small enough to fit the bellhousing, i believe i need a 153 tooth to fit the bellhousing, but the hole on the 153 tooth flywheel that i got is to small to fit the crank on my 350, i have talked to a couple people and from what i understand i can not get a flywheel the correct size new. if you know where i can get one i would greatly appreciate it. Oh the 350 is the pre-86' block, dont know if that is relevent but thought i would add that in.
Old Sep 2, 2011 | 05:49 PM
jminton's Avatar
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
Re: 350 to a T5
one piece or two piece rms?
Old Sep 2, 2011 | 05:59 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: 350 to a T5
T-5 is to weak for the 350 from my understanding.
Old Sep 2, 2011 | 08:06 PM
kyle7148's Avatar
Re: 350 to a T5
two piece rear main i beleive, and i am aware that the T5 is weak but money is a little tight right now, but the car hasn't been driven in two years and i don't think i can wait for the money to buy a T56
Old Sep 2, 2011 | 08:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 350 to a T5
you can get a 153 tooth wheels for a 1pc or 2pc rear main, its just he matter of getting the right one. IIRC, the 2 piece wheels have a larger hole. maybe you got the wrong one? measure the diameter needed and compare at the parts store.
Old Sep 2, 2011 | 08:59 PM
jminton's Avatar
Car: 1985 IROC
Re: 350 to a T5
http://www.summitracing.com/parts/ZZZ-50-6516/
Does that one work for you?
Old Sep 2, 2011 | 09:00 PM
kyle7148's Avatar
Re: 350 to a T5
i did get the wrong one, but i went back to the parts store by me and they have the correct one on file but cannot order it.
Old Sep 2, 2011 | 09:03 PM
kyle7148's Avatar
Re: 350 to a T5
Originally Posted by jminton
This will probably work i am going to order it, the worst that happens is i have to send it back
Old Sep 2, 2011 | 10:30 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Re: 350 to a T5
Not entirely true, I have a mildly built 350 backed by a built T-5 and has held up great so far. I love the combo.
Old Sep 2, 2011 | 10:59 PM
Re: 350 to a T5
I guess it depends on the tranny being built and how much hp and torque your motors putting out. Learning something new everyday.
Old Sep 3, 2011 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 350 to a T5
I run a non-WC behind a 350/330. The general consensus on TGO is that if the car is driven in a reasonable manner, the T-5 will hold up (mine has for a number of years). If, however, the car is rodded hard (sticky tires, hard shifting, etc.), the trans will be on borrowed time.
JamesC
Old Sep 3, 2011 | 10:57 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 350 to a T5
Yes they can.
A flywheel for an '85 V8 Firebird works for '85 and older SBC (except 400)
A flywheel for an '86 V8 Firebird works for '86 and up SBC (all)
Either has a 153 tooth ring gear. If it's diameter is larger with 168 teeth, it's not correct for a third-gen Firebird. Period.
Neither is discontinued. Both are available aftermarket. Either can be had for a reasonable price.
Both can be had in lighter weight (16lb) version as well as heavier (25-30lb?) versions.
Your parts store failed you. Take your business elsewhere.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
