new gears in rear?
Old Sep 10, 2011 | 11:39 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
new gears in rear?
So i did some searching and haven't found anything quite what i was looking for answer wise, i hope someone hear will have what i need. I am looking to get a better take off and want to put in a new ring and pinion. I'm thinking a 3.83 should be good, i think i have a 3.07 or whatever came stock with the 82 berlinetta 4bbl carbed v8. Im not so great with cars yet so bear with me haha. I have a rebuilt 3 speed auto th200c with heavy duty shift kit, and want something to give me at least a good chirp at a light without destroying my already terrible mpg (around 12-14 on a good day) i don't cruise a lot on the highway, but when i do its for a long haul. any suggestions on what i should look for ratio wise and does anyone know how much they will hurt mpg and top speed?
Old Sep 11, 2011 | 09:32 PM
Dabesiv's Avatar
Re: new gears in rear?
bump
Old Sep 12, 2011 | 06:22 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
me personaly i have 5.0 4brl carb and a 700r with 3.42 gearing and i wouldnt go too much lower. At a certain point too low isnt good beause it kills your topspeed and even doing freeway speed the caer has to rev higher. Use this link to track down your rear diff ratio https://www.thirdgen.org/1982-chevy-camaro
Old Sep 12, 2011 | 08:57 PM
Dabesiv's Avatar
alright, well looks like i have a 3.23. Idk how low to go though haha thats where im stuck, i want some chirping at a light but i dont want to be paying much more for gas because of it. If i remember right, the 700r4 is an overdrive trany which is much better for those mpg on highway, and im not lucky or rich enough to have an overdrive so i fear the highway will put a hole in my tank if you know what i mean
Old Sep 12, 2011 | 09:19 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
As the #s get higher, your highway RPMs will increase, hurting your MPG.
So you would want a lower #, like 3.23/2.73 for better highway MPG, but the lower #s will also hurt your take-off, even if just from a stop at a red light.
A 700R4 would allow you to retain take-off & improve MPG. Getting new gears put in & set up correctly can be pricey. I'd look into the cost of a 700R4 & compare that to the cost of gears + having them put in & set up.
Old Sep 13, 2011 | 04:14 AM
Dabesiv's Avatar
yeah i still have to give my transmission guy a call to see what he'd charge, but i usually get some cheap deals with him. id love to put in a new trany all together probably a 700r4 or 2004r, but i just had mine rebuilt about 3 months ago and it would be a waste of some hard earned money to throw that baby out so soon. I don't mind a little mpg difference on the highway, i just don't want to be at a half tank after 40 miles. and top speed isn't too huge since i rarely go over 100.
I just want to not only leave the ever so annoying ricers in my dust but leave them there with a squeal in their ears. I'm not saying make them spend hours removing rubber from their front end(but that would be fine with me =P) but something to get them to notice
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
