Which gearbox do I have?
Old Sep 21, 2011 | 07:24 AM
Misanthrop's Avatar
Been having some problems with my camaro's automatic gearbox as of late. It doesn't switch out of 1st until 3500Rpm and the same for second and third.
Then when it changes into 4th theres an almighty thud in the car before it does so.
I'm going to get a company to overhaul it and they need to know which Gearbox is in it.
1987 Camaro I-ROCZ Vin number. *G*FP2*FXHN34*7* (Q-9821)
5.0 TPI V8
Everything else is standard.
Old Sep 21, 2011 | 07:51 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Re: Which gearbox do I have?
700r4.
Old Sep 21, 2011 | 07:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Have you tried adjusting the TV cable? www.thirdgen.org/detent
Old Sep 21, 2011 | 09:19 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
adjusting the tv cable may fix it at no cost.
Old Sep 28, 2011 | 06:42 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
5.0 TPI V8
if THEY are asking YOU which gearbox is in it, find a different place to take it, they should already know.....
and try the TV cable thingy posted above first, these guys are right, that may fix it at no cost, unless the valve in the valve body is hanging, which isn't unusual for that cast iron valve body. Then the valve body needs to come off and clean and polish the TV valve itself. Find a different trans shop to do it.
Old Sep 28, 2011 | 06:51 PM
zenish's Avatar
Engine: 305 tbi
i had a problem with my 84 camaro where it wouldn't shift.the problem was a plastic gear on the governer that had lost its teeth.new gear fixed it.
Old Sep 28, 2011 | 07:56 PM
greggbruce's Avatar
yep, those don't shift AT ALL. He says his shifts at 3500, even to 2nd and 3rd
AUZ28
Oct 3, 2015 06:28 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
anesthes
Aug 24, 2015 08:32 AM
CAMAROsc350
Jul 19, 2003 02:31 PM
EmuMannen
Feb 23, 2002 07:44 AM
