clunking while shifting?
Old Oct 17, 2011 | 09:55 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
just recently i noticed a clunking sound near the rear of my car as i shift up into any gear. what could this be? ujoints? rear? i just changed the fluid in it last year about this month and my tranny mount is new and i just replaced the filter and fluid on my tranny so im confused?
Old Oct 18, 2011 | 07:33 PM
Engine: L31 350
Re: clunking while shifting?
anyone
Old Oct 22, 2011 | 07:33 PM
Engine: L31 350
Anyone
Old Oct 23, 2011 | 06:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the transmission mount is OE rubber, it's not terribly substantial even new, so you might take a peek.
JamesC
Old Oct 23, 2011 | 10:38 AM
Engine: L31 350
Just replaced the mount a few months ago, also just changed tranny fluid and filter, and did a diff oil change about a year ago. Only thing I haven't done is u joints and those are still factory
Old Oct 24, 2011 | 09:37 PM
Engine: L31 350
bumb....
Old Oct 25, 2011 | 10:49 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Rear u-joint? Place the car on a lift or securely on jack stands with trans in neutral and the parking brake released. Try rocking the driveshaft back and forth and see if you can feel any play, or recreate the sound. If the noise is not in the driveshaft, it could also be in your rear axle. What weight of gear lube did you use? I know that factory spec is 80-90 GL-5 but with many miles of wear we tend to develop increased clearance in the rear end gears. This can cause noise with the OE recpomended lubricants. That's where a good synthetic 75-140 gear lube comes in. The higher sheer strength of the slightly heavier, synthetic lube will greatly reduce gear contact and the noise.
Old Oct 25, 2011 | 02:46 PM
Engine: L31 350
Used 80-90 gear oil
Old Oct 25, 2011 | 03:14 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Yeah, follow my directions above to find the clunk and fix it. Or at least greatly reduce it. If the rear gears are getting real loose, you may just be due for an overhaul.
Old Oct 25, 2011 | 03:30 PM
Engine: L31 350
Might be. I'll do this this weekend. Weird thing is that I just started noticing it and the only thing I haven't done is the ujoint so I'll see what needs to be done
F-body driver
Mar 6, 2023 11:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
