Truck 700r4 for my 88 Camaro
Old Oct 25, 2011 | 04:36 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
Ive searched the site and know you can put a truck 700r4 into a 3rd gen. You just have to swap the tailshaft housing that specific for a Camaro. Adding a shift kit will help get a better performing shift as well.
In one of those posts about the topic a member stated that in order to take the tailshaft off yould need to disassemble the whole transmission. Is this true? I can install a shift kit but if i have to disassemble the trans to put a camaro tailshaft on it, it wouldnt be worth the hassle.
I ask because I can get a truck 700r for about 150 bucks, where at a local salvage yard a good used one specificly out of a Camaro will cost about 250 +core.
Thanks for the input.
Old Oct 25, 2011 | 09:02 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: Truck 700r4 for my 88 Camaro
If it's a 2wheel drive truck trans, your good to go. A trans from a 4 wheel drive has a shorter output shaft and won't work. Just remove the 4 bolts holding the tailhousing and it will come right off. Later model trucks have a metal reluctor wheel where your camaro trans has a plastic speedo gear. Remove the metal wheel and replace it with your plastic gear.
Old Oct 26, 2011 | 06:48 AM
chevman24's Avatar
Thanks! And yes it is a 2wd trans. I failed to mention that part in the op. Im trying to find out the year of the trans as well if its older than a 1988 trans im going to pass on it and get one from the yard.
junkcltr
Aug 2, 2019 11:12 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
Wylecoyote08
Nov 6, 2015 03:46 PM
