Shift Know Stripping Out!!!
Old Oct 18, 2011 | 09:59 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Does anyone have this problem or is it just me? i think i have either pulled the brass insert out of the **** itself or just stripped the threads on the shifter assembly on every stick i have ever had!!!! (BUT 1) and i cannont find the ball anywhere im wondering if anyone has had this issue and resolved it. This question is technically for my 4th gen but will apply to my 3rd gen anyways.
P.S. No gorila glue does not work...lol
Old Oct 18, 2011 | 10:11 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Shift Know Stripping Out!!!
Get a solid alum. ball with a locknut from Jegs.
Use a 3 foot bar to tighten.
See a shrink about your nervous **** tick.
The Loctite or 3M two-part epoxy used to hold the bushing to the shift linkage lever (under the shifter) will hold a lot of things together strongly.
Old Oct 23, 2011 | 01:44 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I didnt like the idea of loctiting my shift **** for various reasons... So I just found a jam nut and used that. It rarely comes loose, when it does I just tighten the **** against the jam nut and it works fine. It's a weird thread pitch, but I found it at a local Ace store after looking a minute or two.
You cant just buy an aftermarket shift ****?
Old Oct 23, 2011 | 02:25 PM
jmd's Avatar
jmd
That's not what I was saying but I can understand why you'd misunderstand.
Let me repeat for clarification.
The Loctite brand or 3M brand two-part epoxy used to hold the bushing in the T5 and T56 offset shift lever would stand a chance of holding a brass insert into a shift ****.
If you used it to hold a threaded **** onto a shifter stick, that would be effectively stuck together as an assembly with very little hope of coming apart.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
