wont shift into park. Any ideas
Old Oct 19, 2011 | 07:09 PM
rob2000gt's Avatar
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
Ok I replaced my shifter cable 5 months ago and shifted fine. The other day it stopped going into park It is like the cable is too short,shrunk or too weak to push the linkage at trans. It is adjusted as far as it will go. All the other gears are perfect. It kind of feels like the linkage at the trans is too stiff or cable too weak. When I shift the car from underneath the gear selector locks in park like it and moved the gear selector exactly where it should. Is it possible the linkage at the trans is worn out, is it replacable without rebuilding the trans?
Old Oct 19, 2011 | 07:12 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: wont shift into park. Any ideas
It sounds like the link to tranny isn't bolted right. That happened to me when I replace my tranny seal. Just had to adjust it
Old Oct 19, 2011 | 07:57 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
is it something easy to do?
Old Oct 20, 2011 | 09:13 AM
torque_is_good's Avatar
you're going to have to go under the car and verify that it goes into park when you move the lever from underneath. If it does, then it's a simple mechanical problem you face and once you are under there, it will be obvious to you; no worries.
Old Oct 20, 2011 | 05:37 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
I can put it in park from underneath
Old Oct 21, 2011 | 01:40 PM
well there you go
now it's time for you to do the rest.
you are there
your eyes can see
have confidence
it's probably a clip, or tie or nut that's too tight (i've seen all attaching the cable)
you can do it
you at least have good news that it shifts and know it's just an adjustment underneath
Old Oct 22, 2011 | 07:24 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Well this was fun figuring this out. Layed under my car telling my 4 year old daughter to try to put my car in park. So trans linkage is fine, the plastic on the shift cable broke thank god for warrantee's.
someone972
Aug 30, 2015 12:52 AM
suzuki949
Aug 28, 2015 08:07 AM
spaigo
Aug 21, 2015 07:46 PM
dhonda200
Aug 11, 2015 11:50 PM
