89 5-speed ECM in 92, is it compatible?
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
If I use an 89' T5 ECM when doing a 700r4 to T5 swap in a 92, will it be compatible with the rest of the car? Both are TBI cars. Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 5-speed ECM in 92, is it compatible?
are they both tbi ecm's? they should both be 1228746 if so yes they will interchange.
Yes, the current one is a 1992 TBI 700r4 ECM and the one I'm looking at getting is a 1989 T5 TBI ECM
Engine: Lb9
Transmission: M20
your old ecm will be fine the only differance is in the pro programing. yours now will send a lockup signal a 42 mph to lock the torque converter clutch. it will work with a t5 if you ant to make it a little better just get a prom for L03 t5 tbi
Ok, I want to swap in the T5, but know that it's better to have the T5 Prom too. I know the TBI cars are practically the same from 89-92, correct? Is the Prom inside the ECM?
Engine: Lb9
Transmission: M20
the ecm service number 1228746 is the same the prom is the only differance. there is 3 to 4 letters on top of the prom called a broadcast code that is the programing code. The prom is inside of the ecm just pull the access cover on top of the ecm.
GREAT! Thanks again. Got the answer I needed. I bid you good day, sir.
