Torque Arm Bracket, and Passing Gear Cable
Old Dec 11, 2011 | 05:35 PM
bangschr's Avatar
Does anyone know where I can find a torque arm bracket and passing gear cable? Also, how do I install a passing gear cable and transmission line?
Old Dec 11, 2011 | 10:22 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Torque Arm Bracket, and Passing Gear Cable
I think they're different auto to manual so get the right one.
A TV cable is in the 700-R4 which is critical to have ajusted correctly. A TH350 has a kickdown cable which is less critical.
More detail, more detail.
Old Dec 12, 2011 | 04:06 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
maybe your local wrecker for the parts. make sure on the trans line that it's metal, or trans approved rubber because the fuel line will blow out under atf pressure and catch your car on fire!
Old Dec 13, 2011 | 06:37 PM
bangschr's Avatar
It has a 700 R4 (automatic) in it (which I just had installed). The cable doesn't quite reach the lever it is supposed to attach to. It falls short by about an 1.5". I have tried to locate the cable, bracket, and hose for the transmission but have fallen short.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
