Has anybody had a driveshaft failure on a stock car?
Old Dec 13, 2011 | 08:38 PM
cerberus's Avatar
Car: 1985 IROC
My vibration is minimal yet still annoying on the highway. I have an opportunity to buy a 93-02 aluminum driveshaft and was wondering if I am over reacting.
Old Dec 13, 2011 | 09:07 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Has anybody had a driveshaft failure on a stock car?
Lots of people here using a thicker, firmer poly trans. mount have vibration issues. I'd start there. Vibrations are tricky to track down; feel free to post more detail.
For a stock car, a 4th gen driveshaft would be fine. For a strength upgrade, I'd skip them since some were thin-wall, cardboard damped compromise.
Old Dec 14, 2011 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Do you have the single-piece trans cross member or the type with the secondary cross member (my 85 was equipped with this latter)? In either case, worn mounts might be the issue. I'd verify that before I dove off the deep end.
And if you find that you have the secondary cross member, you might consider swapping it for the single-piece.
BTW, if you've installed a poly mount, you may find the link below interesting:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
gwade12
Aug 8, 2015 08:17 AM
mustangman65_79
Aug 8, 2015 01:18 AM
