having posi gears welded in
Old Dec 11, 2011 | 10:23 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
does anyone know where i could take my rear end to have posi gears or spider gears welded into my limited slip rear end? how much does it normally cost/
Old Dec 11, 2011 | 10:30 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: having posi gears welded in
Um.. Limited slip Is "Positraction"
if you have an open rear end, its usually easier to just swap the whole rear end.....
Old Dec 12, 2011 | 04:02 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
ha ha, i had a friend that welded the spiders in his 60's chevy truck and with the b&m shift kit behind the th350 it would really lay the stripes on the road into second. it only lasted for the summer though before the carrier broke, but it was what he could afford if you know what i mean.
Old Dec 12, 2011 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The idea generally isn't recommended. A search might provide more insight.
JamesC
Old Dec 13, 2011 | 09:34 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
So in an attempt to save money he ended up costing himself more money to replace everything that broke.
To the OP, like James said, welding the differential spider gears to make a "lincoln locker" is not recommended. Especially if it sees any street time.
Old Dec 14, 2011 | 10:53 AM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
why dont you just buy a spool
IROCtometal
Sep 20, 2015 11:08 PM
fasteddi
Sep 10, 2015 09:32 AM
IROCtometal
Sep 9, 2015 10:01 AM
Dialed_In
Aug 20, 2015 01:45 PM
