4.56 gears in 10 bolt rear
Old Dec 13, 2011 | 12:26 PM
Drewmeyes88's Avatar
Car: 88 firebird ws6
Engine: 350 tpi
Transmission: 350 turbo
Ok so I searched and I can't seem to find an answer on putting 4.56 gears in my 10 bolt...I have a rear end from a 96 ss camaro it has 3.42 gears in it and has auburn posi. So can I put 4.56 in it?
Old Dec 13, 2011 | 05:42 PM
Re: 4.56 gears in 10 bolt rear
Sure. Why not?
Old Dec 13, 2011 | 05:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sure, don't expect it to last long with how small that pinion will be.
Old Dec 13, 2011 | 06:04 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You sure can! If you like broken stuff to hang on the wall..
Old Dec 13, 2011 | 07:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need a special crosspin that's thinner than normal to clear the 4.56 gears. Just another weak link in the diff.
Old Dec 13, 2011 | 11:56 PM
Engine: 350 tpi
What will break? So what about 4.10 gears then
Old Dec 14, 2011 | 07:27 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Instead of going to an extreme with one aspect of the car, try matching engine powerband to the gear you have going on.
An L98 with stock intake manifold doesn't overall benefit from "too much" rear gear. Unless it's something with mods that push the powerband up a lot, 3.73 is about the absolute max I'd go with regard to 1/4 mile and drivability.
I'm a huge fan of overdrive and lower rpm on the highway, so w/ a TH350, I'd go even less but that's me.
Old Dec 14, 2011 | 08:15 AM
Engine: 350 tpi
Well see with 3.42 gears I can barely go on the highway and I really don't mind just having a car to just drive around town...I do want to get a better engine but that's later down the road. So o was just gonna get low gears for now.
Old Dec 14, 2011 | 05:07 PM
jmd's Avatar
jmd
Right; 3.42s without OD aren't enjoyable on the highway either, in my opinion.
I'd save up to go 700-R4 or even 200-4R. Either would give you a shorter first gear and very good highway manners. With a lock-up higher-stall converter, that might give you a best-of-both worlds scenario.
If you were soon (or had already) going to a higher rpm powerband engine, that would be when you'd benefit from getting more gear than 3.42.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1nastygta
Aug 8, 2015 07:38 PM
