so my trans is leaking
Old Dec 23, 2011 | 08:37 PM
emerald91fbird's Avatar
Car: 1991 firebird
Engine: 3.1 l v6 mpi
Transmission: auto
i cant quite tell where it is coming from but i was driving last night and the car was smoking (leaking fluids onto the exhaust burning off)
well i was leaking trans fluid and alot of it everyone i have talked to says it sound like a line burst or broke or maybe a fitting i looked where the rear main is and it doesn't look like its leaking their it looks further back and i lost more then a pint of fluid and it no longer is leaking (have not turned or or ran the car since i had it towed last night)
so any ideas on figuring this out so i can fix it?????
the car is a 91 fbird 3.1v6 auto trans
Old Dec 24, 2011 | 01:22 AM
Cosmik Debris's Avatar
Re: so my trans is leaking
Maybe leaking through the transmission front seal? Sometimes stops leaking when you stop, sometimes not.
Old Dec 27, 2011 | 10:34 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If it is a gusher, it should be easy to spot, assuming you have the car up in the air safely, and a flashlight.
There are about 20 potential leak points on that trans. You could always put some uv dye in it, run the car, then look for the glow trail with the special light that comes in the kit.
In the states, the kits run about $50, and save a ton of time and aggrivation.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
wayshegoes
Aug 17, 2015 12:00 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
