werid n00b question...
Car: 89 rs 358 / 99 wrangler 4.0
Engine: 358
Transmission: t5
Axle/Gears: 393 12 bolt
ok so this just started and i have no idea why, but im almost positive it is not good lol, whenever i am at a higher rpm (2500+) the stick shifter will becan to move up and down, not vibrate but physically move up and down about 2 inches, the car still drives fine when it is happening but i would like to know if im on the right track thinking it could be the transmission mount? its an 89 RS with a 358 swap and borg warner T5, any help (or pics of what i should check) would be awsome, thanks in advance!!
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: werid n00b question...
Sounds like a trannsmission mount just jack up on the tranny and if it moves up a lot needs a tranny mount
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the stock trans mount (rubber) is broken and needs to be replaced, not a big deal.
Engine: 358
Transmission: t5
thanks for the quick responses, thats what i was hoping it was
any good aftermarket ones that you all know of? or should i just replace it with the stock rubber one?
any good aftermarket ones that you all know of? or should i just replace it with the stock rubber one? Thread Starter
Engine: 358
Transmission: t5
Hey I have another question about it sorry, is the transmission mount the same mount as the engine mounts? im looking at this one- http://www.carparts.com/details/Chev...suspe1231116r1
and it says it can be either the motor mount or transmission mount?
Car: 1990 Iroc-Z
Engine: 5.7 TPI
No at all. That is an engine mount. The transmission mount is vertical.
Here is what mine looks like, but I would not recommend this particular one.
http://www.autozone.com/autozone/par...er=154518_0_0_
I'd recommend the Energy Suspension polyurethane mount. It's also available at Auto Zone, and they're FAR superior to any of the stock style, rubber mounts. Couldn't find the part online at AZ's site, but I know they carry it. Here's a link for it on Summit Racing's website. http://www.summitracing.com/parts/ENS-3-1108G/
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Before you jump in the water, you might consider the following comparison of available products:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
JamesC
Engine: 358
Transmission: t5
good read, thanks! also thanks for clearing up the motor mount issue, ive had the engine out of my last third gen a few times but its been a few years and couldnt remember, also want to make sure i have the right part before i do this in my apartment parking lot lol, not that its to hard, anyways thanks for the replies
