Just bolted engine and trans back together, is this a problem?
Old Jan 3, 2012 | 08:35 PM
'86 350's Avatar
Car: '86 Camaro SC
This might be a stupid question but I just want to be sure before I put this whole set-up back into my car. It's a 400 sbc mated to a T5. The clutch is one of the Zoom units, I can't remember which one because I bought it almost 3 years ago. The flywheel is a 153t one, I have the weight bolted up behind it to compensate for running a flywheel for an internally balanced engine on an externally balanced one. Anyway, onto my question.
So I just bolted the transmission up tonight, getting ready to plop it all in the car the next day we get above 40*. When I turn the crank over and put the transmission in gear, obviously the tailshaft turns as well. However, when I put the transmission in neutral and turn the engine over, the tailshaft of the transmission still turns. Is this expected since I don't have the clutch linkage or anything hooked up yet or did I do something wrong?
Hopefully that was clear, otherwise I can try to explain myself better.
-Thanks, Brandon
Old Jan 3, 2012 | 08:43 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Just bolted engine and trans back together, is this a problem?
The flywheel turns regardless of in gear or neutral.
Are you talking about the transmission input shaft?
Old Jan 3, 2012 | 09:00 PM
'86 350's Avatar
Car: '86 Camaro SC
Yes, I was simply typing fast and put tailshaft of the engine instead of tailshaft of the transmission. Edited the first post now so hopefully it's clearer what I'm talking about
Old Jan 3, 2012 | 09:35 PM
Car: '87 Camaro
I never thought about it!!!
I would ** think ** yes it would turn because it's directly attached to the flywheel, and the tailshaft turns when a gear is selected.
Well I will learn something too!!
( edit )
I re-read your 1st post after your edit.
The tailshaft ( where the drive shaft attaches ) should ONLY turn when in gear!
The transmission inputshaft ( the 1 connected to the motor ) is the 1 I was thinking you were talking about before your edit.
Sorry if I confused you & anyone else!
Last edited by t-top havoc; Jan 3, 2012 at 09:46 PM. Reason: re-read after OP edit
Old Jan 4, 2012 | 02:00 PM
'86 350's Avatar
Car: '86 Camaro SC
That was my understanding as well. Anyone want to take a crack at what I did wrong then so I know what to look for when I pull it apart?
Old Jan 4, 2012 | 02:13 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Dont quote me on this, but I think the tailshaft does turn if there is no driveshaft when in neutral because of centrifical force.
Now if you do put the shaft in and bolt it up to the rear, then fire the car and it lerks forward while cranking, then the clutch is not disengaging, only if in gear(will go backwards when cranking when in reverse and the clutch is not disengaging).
Old Jan 4, 2012 | 02:56 PM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
with the tranny in nuetral try having some one hold the output shaft on the tranny while you turn over engine by hand.if it takes a lot to hold the output shaft from turning than you have a problem,if it dont take much at all i wouldnt worry about.just an idea to try out but im no expert.when i had my tranny out if i spun the input shaft by hand in nuetral the output shaft would turn just from the centrifical force
Old Jan 4, 2012 | 03:05 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
To answer your question, yes the output shaft will turn even with the gears not engaged. If you cant stop it with your hands (I normally just stik the drive shaft or the yoke on it and hold it) then as stated above, you might need to check all of your connection points over again.
Old Jan 4, 2012 | 03:27 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
A manual in neutral still has internal drag which spins a barely loaded output while the engine is running. If it's a fresh rebuilt trans, have a helper hold the output while turning the crank. If they can. Stop it withe a spare yoke while you turn the crank, you're probably okay.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
