Problem with gear install
Old Jan 11, 2012 | 10:28 AM
italiano67's Avatar
Car: 1989 Iroc
Axle/Gears: stock axle 3:27 gears
I had a local shop install a new used posi series 3 carrier in my 9 bolt rearend and good used 3:27 gears. We rebuilt the entire rearend with new bearings etc and upon driving the car whenever decelerating or letting off the gas I get a loud whine. I dont think it is the used gears being the problem but the shop says it might be the old wear pattern. The noise is very loud when coasting to a stop and i think it is a simple setup mistake. From what I can tell you cant even buy new gears in this ratio and these gears I put in looked in nice shape. I am not going to drive it and probably will bring it back but it is irritating the we have to open up the rearend and half to go through the entire process again. We might have to do this multiple times to eliminate the noise right?
hectre13
Dec 11, 2023 08:14 AM
rocn7roc
Sep 21, 2021 02:16 PM
hectre13
Aug 26, 2015 08:17 AM
TheJoeY88
Aug 13, 2015 06:51 PM
dhonda200
Aug 11, 2015 11:50 PM
