What's correct WOT shift RPM stock 350 TPI Car
Old Jan 16, 2012 | 04:01 PM
JP007's Avatar
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
89 Formula 350 Firebird. When I have gas to the floor WOT what rpm should this car shift? I was told 4800 rpm as it is low rpm torque motor. Can someone verify please. Or what would be recommended part# for a governor for this 700R4?
Old Sep 1, 2012 | 11:47 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: What's correct WOT shift RPM stock 350 TPI Car
Wish someone would have replied to this one back when you posted it lol. I just swapped in a slightly older trans in my 91 'bird (86 trans) and now it downshifts into second but drops into 3rd at around 4500. I think it's probably normal, as I always noticed on the old one, it ran into around 5000 but felt like it was losing power there, so this could very well be right. Would love to see a part # also for the correct governor though if it is wrong.
Old Sep 2, 2012 | 06:47 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Stock L98s seem to be done at 4800. B&M sells governor recalibration kits so you can start with the common 4200-RPM governors and tweak them up to whatever you like for each shift. Changing axle gearing will change shift RPM unless you change the governor.
Old Sep 2, 2012 | 07:13 AM
JP007's Avatar
Car: 89 Formula
The Corvette governor PN#2420117 and the correct one for the car is PN#2420118 but can be only be bought as a reman. GM mech told me this. Unless you are pulling hard all the way to 5K on the tach the stock I am thinking is the best choice as it quits pulling at that rpm anyway. I sold the car a while back. 60k original miles dual cat, super clean.
Old Sep 2, 2012 | 02:03 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Stock I think 5500
camaro71633
Sep 1, 2015 10:24 AM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
dhonda200
Aug 11, 2015 11:50 PM
